Author Subject: Jenvey Questions
Stuwee
Just have a few questions regarding swapping Jenvey bodies from an s16 (RFT) to a gti6 (RFS) engine.
1.Is the inlet body itself interchangeable between the two cylinder heads??
2.What sort of power gains are there to be had with jenvey's on a standard/fast road cam'd 6 engine??
3.The s16 is running an EFI ECU and i was wondering weather the ECU on a Gti6 (RFS) engine can be altered to run Jenvey bodies??
Just gathering idea's together at the moment on what to do.
Stuart
Ph1 Cossack 6
Posted 5th Jul 2011 at 02:47
When I bought my throttle bodies from Jenvey the manifold was listed as an Mi16, so if it fits that and a gti6 head, would guess it would fit yours.
With some half decent cams and jenveys you should see around 200-210 bhp.
The standard ECU can be remapped by the likes of Wayne, but why not use the EFI ECU?
Posted 5th Jul 2011 at 03:20
I have a brand new Jenvey maniofold in a box, yours for £100 delivered.
Posted 5th Jul 2011 at 19:58
pugjim
jenvey Inlet manifold is the same for the s16/mi16 and gti6.
I would use the EFI ecu from the s16 as it will already have a good base map for the gti6 engine to get it up and running then have it mapped properly after.
Posted 5th Jul 2011 at 23:36
Stuwee
Thanks for the info.
The s16 engine currently is putting out 185 to 195 Bhp(preivous owners quotes). She does not feel she has got that at the moment Sad.
Hesitation and over fueling are the main issues.
If you are only able to squeeze around 200-210 Bhp out of a cammed RFS engine then i might just stick with the s16 lump until my pockets gets deep enough to go down the major engine internals mods/Sc route.
Rolling road and re map here i comeNinja
Ph1 Cossack 6
Posted 6th Jul 2011 at 05:17
Stuwee
More questions.....
I have 45mm jenvey's with 48 length trumpets running euro 1 efi ecu and i presume original bosh injectors off the avac set up on the S16.
Basically i now want to put these bodies on a standard RFS lump, i do not have a massive budget and cannot afford another £1000 on pistons and cams.
Any ideas on the power gains on a standard RFS engineUnsure
I also presume i would need to upgrade the injectors so any recommendations??
If there is anything i have missed which i need to do to make this transplant a success please let me know.
Thanks
Ph1 Cossack 6
Posted 1st Aug 2011 at 03:07
will130787
I don't think there is a huge amount of gains on a standard rfs engine bud, bit the noise Smile
Still undecided what to do as mentioned at pugfest?! I would get the s16 mapped properly Wink
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 1st Aug 2011 at 03:17
get it mapped properly and a decent exhaust inc manifold if it hasn't already, they do perform quite close to the rfs when built up properly (most maxi's ran RFY based engines)
Posted 1st Aug 2011 at 03:32
Stuwee
Yes it has got a 4 branch manifold,piper 272 fast road cams and the 6 gearbox to boot.
I have been told she is running 185+ but she has shown not be any faster than a 6LOL
My main thought was instead of faffing about with re maps and other issues that i have found is to start fresh with a standard RFS lump but if the power gains are only improve BHP to circa 180 then it is not worth the hassle of the swappage.
Ph1 Cossack 6
Posted 1st Aug 2011 at 04:35
