Author Subject: squeaky rear suspension :S
jimmyhackers
the rear torsion bar setup is very aqueaky and its rather embarrasing when driving Sad
ive taken a 1.4 306 apart and lowered it so i have a pretty good idea of what the job entails.
im guessing its it a case of taking it apart assesing extent of damage. hopfully its just moisture and perished seals. and needs some grease
is there anything else it could be?
or will a shed load of grease do Razz
Posted 4th Jul 2011 at 05:04
darkgti6
are we talking about a squeek here or a creak? How old is the beam and has it been taken apart before?
Team Peugeot Sport 308 Gti�
Posted 4th Jul 2011 at 05:43
jimmyhackers
16 years old, ex silverstone car, doesnt look like its ever been touched, will be a "joy" to dimantle Razz
its a loud creak and lots of other little squeaks. the vibrations can be felt the most on the tube that houses the anti roll bar mainly on the passenger side. the wheel on that side does look slightly out of alignment compared to the other wheel. however my drive is slanted so i could be wrong.
i replaced the front suspension with coilovers last weekend and that has made it quieter. but i figure thats just becuase the cars not wobbling and rolling and bouncing about due to crappy 16 year old shagged front suspension.
anyone fancy writing me a shopping list including prices of what i could need to rectify?
Posted 4th Jul 2011 at 05:52
darkgti6
At that age the beams failed by the sounds of it. Time for an overhaul.
Speak to miles on here. He can supply you with pretty much everything you will need I think.
Hopefully the beam will still be salvageable. Sometimes the bearings can disintegrate and the arm shafts start wearing out the inside of the tube which is what happened to mine. Then the new bearings cant be seated properly.
Of the top of my head you need a miles rebuild kit which gives you all the consumables you need like seals and bearings which is about 75 quid and 2 new arm shafts from miles again which are 70 quid each.
If there is any wear on the old arm shafts replace them without question. A rough surface will knacker new bearings very quickly and you'll be back doing the same job again very soon. Best thing to do is to do it properly once imo.
It will probably be a b*tch to get apart. I had to get the tb's pressed out of the trailing arms and one of my anti roll bar end plates was stuck on the antiroll bar so i had to buy a new one (i put a hybrid antiroll bar in)
Also I had trouble getting the old bearings out and didnt feel confident pressing the new ones in so I got miles to do it in the end.
Posted 4th Jul 2011 at 06:08
jimmyhackers
sounds wonderful Smile
how much to get someone to do it all for me? im in the birmingham area so a localish garage/person would be preferable.
i would tackle it myself but due to the nature of my work im away for weeks on end.
would be nice to hand it over and come back a week later and find its all sorted by somone who knows what there doing and has the correct tools.
my method of seating bearings usually envolves a block of wood and a lump hammer Razz
Posted 4th Jul 2011 at 15:01
smegal
It can cost anywhere in between 150 and 350 depending on what's wrong with it.
Ex SC-6
Now in a Megane R26
Posted 4th Jul 2011 at 15:33
jimmyhackers
that seems resonable
cheers for the info
Posted 4th Jul 2011 at 17:02
smegal
I had mine done at Mechanical_Repairs in Leicester. Mine was at the higher end as it needed a new pin (Mine has groves from the needle bearings) and some twat had welded everything together.
The car feels so much better now.
Ex SC-6
Now in a Megane R26
Posted 4th Jul 2011 at 18:48
