I am aware that this is no sequential GB, bu could someone be so kind to explain me how this is supposed to substitute the original gear lever?
clicky
Thanks for looking
| Author | Subject: Can someone tell me what this is? |
marco gti6
Seasoned Pro Location: Troisvierges Registered: 09 Mar 2009 Posts: 1,350 Status: Offline |
Hello fellow members i just stumbeled across this nice looking piece of kit on a french 2nd hand site.I am aware that this is no sequential GB, bu could someone be so kind to explain me how this is supposed to substitute the original gear lever? clicky Thanks for looking |
rallyeash
that won't work with a H pattern standard gearbox. need a sequential GB ![]() ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
c_j_m
Seasoned Pro Location: Andover Registered: 23 Sep 2007 Posts: 1,917 Status: Offline |
TBH it looks to work in a very similar way to the cable operated boxes that come on the newer pugs.It would still have the standard gear layout, but with a short throw? |
marco gti6
The description clearly says this can be used on the standard 6 speed gearbox. I was just wondering how this would take over the part of shifting through the H patern of the GB.Still would look smart :cool |
marco gti6
Just found this on the manufacurer's site:http://www.bacciromano.com/index.php?p=prodotti&l=eng&cat1=24&cat2=47&mar=6 13650€ for a sequential GB ready to throw in. |
clen666
Does look like the linkage on the right of the unit works from the left/right movement of the stick![]() ________________________________________ Team 'unintentional rat look' |
bobdylan_55
Seasoned Pro Location: derby Registered: 28 Mar 2009 Posts: 1,466 Status: Offline |
linkages look very similar to the ml5t ones...________________________________________ 309 GTi6-T |
yeap, there's lots of BE4 boxes using cables too, but that kit on the first link is designed directly for a standard H pattern 306 gearbox.have seen similar in a group A Xsara last time I was in belgium. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
marco gti6
welshpug! wrote: yeap, there's lots of BE4 boxes using cables too, but that kit on the first link is designed directly for a standard H pattern 306 gearbox. have seen similar in a group A Xsara last time I was in belgium. So this lovely bit of kit transforms the Hpattern box in a up/down shifting lever? Seems pretty cool |
c_j_m
I doubt it tbh, will still use the standard gear layout I'd have thought. |
can't see how left to right movement is achieved ? only back and fourth ? |
gtylerroberts@manx.net
Regular Location: Ramsey Registered: 24 Mar 2008 Posts: 102 Status: Offline |
If you look closely at the mounting of the gear lever it allows movement side to side and has a drop link to transfer to the gearlink cables like clen said |
yeah, works exactly as std H patten, just taller less play and shorter more precise shift, also engine movement will not move the stick about________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
