Author Subject: abs sensor
sheepdog
any tips on taking off abs sensor on rear disc brakes total seized in, dont want to heat it incase damages inside it????
Posted 30th Jun 2011 at 01:24
pugjim
You will be lucky if you can get it out without destroying it. You could try soaking it in plusgas before you try to remove it.
Posted 30th Jun 2011 at 01:27
sheepdog
broke 1 already!lol they arny cheap! i will give that a try cheers, its going to be an expensive beam change!
Posted 30th Jun 2011 at 01:33
gota6again
Mine ended up the same way, had to spend an extra £170 on bits that broke during the change Crazy
Posted 30th Jun 2011 at 01:38
sheepdog
am workin up to that aswel, had to change shocks and compansator valve and brake lines so far! and only needed to change beam for M.O.T!!
Posted 30th Jun 2011 at 01:45
miles
Good luck, Think I have saved 1 in quite a few, Price wise thou new are only £48.00ish + VAT
www.pugracing.com
Posted 30th Jun 2011 at 01:46
