Author Subject: starting issues
fillmecca
I came to start my car last night after work turned my key all lights on dashboard on as normal it just wouldnt fire. It wouldnt turn over at all couldn't here the starter motor even making a clicking noise. So I bumped it and after that it seemed to work fine all night while I turned it off n started about 6 times.. untill this morning and it won't turn over again.... any help would be much appreciated
Could it be started solenoid, starter motor itself, any ideas would be helpfully as its used daily to get to work and back
Cheers Phil
Posted 29th Jun 2011 at 13:58
mark t
I've got a problem very simmilar to this, I initially thought, that it was the battery gone but is the starter motor they sometimes get dead spots on them and you turn passed them most of the time. Then you land on them and cant start
Posted 29th Jun 2011 at 22:22
pugjim
Sounds like the starter motor brushes, if you can find an auto electrician that will sell you the brushes there easy to change. just be careful not to loose any parts when you take the motor apart.
Posted 30th Jun 2011 at 01:01
fillmecca
Cheers guys.. well I'm picking up a brand new starter motor tonight after work. Shall be fitting it on Saturday. I've looked through the forum and Google some people are saying you need ti remove the inlet manifold.
Posted 30th Jun 2011 at 19:49
mark t
Sounds about right. You may be able to do it by removing the rad and slam pannel. Only issue with that would be that the air-con would need re-gassing. But i'm sure that doesn't work anyway!
Posted 30th Jun 2011 at 21:16
bobdylan_55
if it does it again before you get chance to change it, try smacking it with something
309 GTi6-T
Posted 30th Jun 2011 at 21:43
fillmecca
Starter changed yesterday. I decided to renove the inlet to get to the starter motor.. all seems fine now thankgod. And air con doesn't work anyway it broke on the previous owner so he removed it.
Posted 3rd Jul 2011 at 15:10
