Author Subject: Supercharger boost options
judley
I'm leaning towards supercharging my 205 GTI-6 and have a couple of questions. I know the low boost option gives circa 250hp and the high boost gives up to 400hp but is there something in between, i.e. medium boost?
If so, what sort of PSI are we talking about and are the changes in power output driven by boost pressure and injector size or are there other considerations like upgraded intercooler etc.
What sort of power/torque levels are the accepted limits for clutch/gearbox/driveshafts etc. and when do you need an LSD?
Any assistance appreciated Cool
Cheers,
George
Posted 29th Jun 2011 at 02:27
There is only low and high.. Low boost is standard pistons and compression. High boost is forged piston/rods etc so if you have to do that, then why not have 400bhp? Laugh
I'm sure you could still run a restrictor ring with high boost setup and have whatever you want, but I wouldnt see the point.
Posted 29th Jun 2011 at 02:30
spiky
i have thought about this, as engines are throw away items,
next year i may open up the restrictor and get wayne to re map it, and see if i can get around 300bhp
worse that can happen is a enginer fail, an thats only about 200 quids worth, so worth a punt Smile
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 29th Jun 2011 at 02:33
Worst that can happen is a rod through the block destroying the head as well in the process ? Guess if you have a spare its worth a punt Crazy
Posted 29th Jun 2011 at 02:36
masekwm
I'd go for the LSD first, get the suspension and brakes to perfect working order before considering the charger.
Rich E Forum Admin
For a medium boost option without the forged bottom end there's no reason why you couldn't use a decompression plate and alter the restrictor ring to give the right compression and boost to map for 300 bhp.
Longevity would be the only real unknown, but if no-one gives it a go then it will never be answered...
Posted 29th Jun 2011 at 02:39
rallyeash
thats the thing, has any low boost had engine failure because of the boost? worth ago. couldnt the pulley on the charger be changed?
309 3dr K20 Type R
Posted 29th Jun 2011 at 02:52
spiky
Nah just open up the restrictor, as that what controls the boost
I don't have a spare engine, but there is plenty about Smile
MY YouTube Videos'
Posted 29th Jun 2011 at 03:04
rallyeash
get your file out then!
you coming to RS day sat?
309 3dr K20 Type R
Posted 29th Jun 2011 at 03:13
judley
Interesting comments guys, thanks. Not really looking to go through the expense of a built engine so low(er) boost sounds the way to go. Most of the work the car does will be on track so I need some longevity.
To you guys that run a charged 205 GTI-6, do you need an LSD at that power level or can you put the power down okay on track?
Posted 29th Jun 2011 at 03:42
matty_rallye
You would have no hope of going around a track or putting the power down on the road without lsd.
2.1 16v 306 Rallye.
Posted 29th Jun 2011 at 04:05
spiky
Unless you drive like miss daisy a lsd on track is a must
I will be at Combe, but not on track
MY YouTube Videos'
Posted 29th Jun 2011 at 13:50
This just with a SC gti6'd 205, or a 306 too? Unsure
Posted 29th Jun 2011 at 13:41
judley
My thinking on the LSD as well. What are the general preferences for track work then, Quaife, Kaaz or others?
Posted 29th Jun 2011 at 13:45
spiky
it's personal choice,
i fitted quaife as it's fit and forget
the others need maintenance
i get traction ok with my quaife, so happy with it for now, fit i find ui get issues letter on i will fitted a plated diff
MY YouTube Videos'
Posted 29th Jun 2011 at 13:51
russbez
i have a quaife lsd i like it a lot, but im never on track days up here
lsd subject has been discussed a lot if you want to search judley Smile
My Rallye project thread
Posted 29th Jun 2011 at 14:02
rallyeash
anything needs a diff on track. even a standard 306 gti6 on road tyres imo.
309 3dr K20 Type R
Posted 30th Jun 2011 at 00:20
rich_w
You can't really run any more boost than we already do ( 0.6 BAR) without de-compressing the engine - either with different pistons or a de-compression plate.
Running more boost with the 10.8:1 compression ratio will compromise reliability, and the gains you get for each extra pound of boost become less and less - this is because you have to take ignition advance out to suppress detonation.
You can run whatever power you want between 250 and 400 BHP, but you will need to de-compress the engine, and get a bespoke map rather than our standard software.
Smile
Contact Details:
07732 822546
Posted 30th Jun 2011 at 02:39
spiky
Do you have an sc kits out there with a decom plate rich?
MY YouTube Videos'
Posted 30th Jun 2011 at 02:47
rallyeash
260 not enough then?
309 3dr K20 Type R
Posted 30th Jun 2011 at 03:02
spiky
Only done one slow track day, but you always want more lol
It kills me knowing I have a restrictor pmsl
MY YouTube Videos'
Posted 30th Jun 2011 at 03:18
rallyeash
haha, its like sex, enough is never enough....
309 3dr K20 Type R
Posted 30th Jun 2011 at 03:53
matty_rallye
If i started building a track car again then i would put a diff near the top of the list, even with a standard engine, nevermind 260 bhp.
2.1 16v 306 Rallye.
Posted 30th Jun 2011 at 03:56
spiky
Agreed, a diff. Made a big difference for in my 205 when it was just a STD gti6 engine Smile
MY YouTube Videos'
Posted 30th Jun 2011 at 04:14
+1 probably the best single mod you can do in a front driven track car. After that the gains seem to get smaller and more expensive to come by Wink
Posted 30th Jun 2011 at 04:55
