Author Subject: Top engine mount.
mattgti6phase2
Hi all does anyone know the part number for the top engine mount for a 6?
It's the part that sits in the base of the cradle. I have heard they may be oil filled?
Many thanks.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 28th Jun 2011 at 22:21
The stiffer one from Baker BM / Miles is pretty good value and you don't get much more NVH from it, certainly not like a solid bottom mount.
Hope the inner wing mount isn't cracked Wink
Posted 28th Jun 2011 at 22:32
gilesy
If you are going to order one then Peugeot will know it!
Was it broken? Did you go through the faq? My last one was loose.
Posted 28th Jun 2011 at 22:49
mattgti6phase2
I'm going to order one but not from pug just wanted to compare part numbers as my mate is getting me one at trade for £18.
Still unsure if it's broken but I know for certain that when we put a bar between the rubber to stop the flex the knock disappeared. When taken out it appeared again.
So tomorrow using the FAQ I shall strip it out.
5 x a 306 owner!
Posted 28th Jun 2011 at 23:34
mattgti6phase2
On a bit of a budget this month as my little boy should be turning up in the next day or so. Plus I'm having the cambelt changed Huh?
5 x a 306 owner!
Posted 28th Jun 2011 at 23:36
