Author Subject: changed the inlet maniflod gasket an its irratic idlin...?
sparko
had the manofold off to change the starter motor.did that an fired her up. no problems. fitted the gasket today cuz of f*ckin halfrauds messin up my order. now its got irratic idlin... any ideas? had to loosen the throttle cable as it was revvin loud. now bouncin up an down
Cherry Red - Phase 1 Restoration
She's alive again Smile
Posted 28th Jun 2011 at 03:12
sparko
didnt remove the throttle properly, was in a hurry. tried repositionin the clip but still up an down. seems suss how its just suddenly went. is there an idle control valve on a 6? just gettin used to these cars
Posted 28th Jun 2011 at 03:22
Yeah, it's underneath the throttle body, check you have'nt damaged a wire or pulled off the connector or something silly.
Posted 28th Jun 2011 at 03:34
sparko
this'll sound silly but where is it exactly? electrics are a piece o p*ss but not that clued up on mechanical parts. pickin it up quick but names of parts i'm still gettin to grips. deacribe where it is an i'll be fine
Posted 28th Jun 2011 at 03:39
mr swampy s16
**BAD SELLER**
sounds more like you have an air leak on the manifold
were the two faces clean beofre you put the new gasket on?
are all the bolts nice and tight
Posted 28th Jun 2011 at 03:40
sparko
u mean the gray connector? that was disconnected an put to one side
Posted 28th Jun 2011 at 03:41
sparko
...uh might just be a bit of a tit...
dropped the middle allen bolt in the engine bay. pickin up another bolt tomorrow. think its just extra air gettin pulled in from the missin bolt?
Doh
Posted 28th Jun 2011 at 03:44
sparko
if thats the problem i'll be happy.....
might break her if not. she got me from the western ilses to aberdeen, cross country, an she's just wantin to wind me up now.
Posted 28th Jun 2011 at 03:56
sparko
feelin a bit o a tit now.
Posted 28th Jun 2011 at 04:08
honestly3k
If youve taken the manifold off and put it back on with a new gasket and its missing a fastening bolt then i would say it has an air leak too
Posted 28th Jun 2011 at 04:22
sparko
yeah think so too. i'll find out tomorrow when i tighten her up Whistle
Posted 28th Jun 2011 at 04:25
