Author Subject: Power loss and stuttering
hamhead24
Was stopped at traffic lights today and all of sudden it stared to idle funny. Then when I drove of it was a bit lumpy and had no power. I didnt try and rev it up high in case i did more damage. But it didnt seem to want to go higher than 2500rpm. Every now and then it would run smoothly for a second or so before being lumpy again. Any ideas? MAP? Coil pack?
Posted 27th Jun 2011 at 20:32
honestly3k
Lambda sensor? Unsure
Posted 27th Jun 2011 at 20:52
hamhead24
Seems to rev slightly smoother after 3500rpm and a bit more power. Disconnected the lambda sensor and the problem got slightly worse.
Posted 27th Jun 2011 at 23:32
sharvey44
MAP sensor?
Ph2.5 Nile - Slowly trying to de-East London it and restore to former glory...
Built on the 9 Febuary 1999 - Tuesday's car..is full of pace? Wink
Currently looking slightly molested due to some c*nt trying to get into it.. Sad
According to the forum Social Worker, because I work in IT, I am socially retarted..
Posted 27th Jun 2011 at 23:43
dan_s16
Possibly a coil pack failing due to the heat, One of the S16s coils used to do it every now and then in the summer, it sounded like a boxer engine, usually giving it a prod on the throttle would wake it up again and it would run ok again after that.
The coil died completely eventually though (thats how I worked out what was causing it as it hasn't done it since).
Posted 28th Jun 2011 at 00:08
hamhead24
Thanks for the advice. Just cleaned the icv. Will have a go at the map and coil packs next.
Posted 28th Jun 2011 at 22:12
hamhead24
Took it out for a spin after cleaning the icv and it ran very well for about 5 mins than the problem returned. will change for a new one and cross my fingers
Posted 28th Jun 2011 at 23:03
