Author Subject: Drivers window
danposs86
I went to put the window down on my 306, but half way through the glass moved forwards (towards the side mirror) and the edge came away from the door frame. Its now very loose, still goes up and down but I have to hold it while doing so.
Any ideas what it cane be? Maybe fallen off a runner? It was shaking a bit previously before the glass came loose. Also notice that theres a hole in the glass edge that is usually behind the rubber, was there a pin in there that held it?
danposs86's GTi-6
Posted 27th Jun 2011 at 19:17
cooper666
towards the back of the door should be a little hole in the glass with a iirc grey 90 degree plastic clip which runs in the window rubber
clio r27
ps3 id:cooperkloe
Posted 27th Jun 2011 at 22:50
danposs86
I have seen the little hole, but no plastic clip in it.
Might of come off behind the rubber, does it just slot back in.
danposs86's GTi-6
Posted 28th Jun 2011 at 00:15
pebbles167
If its not there it will probably be behind the rubber. Take heed as although the clip has probably snapped or loosened, what causes it (in many cases at least) is the actual rubber door seal its self. It has a felt layer on the inside which once worn down exposes the rougher surface underneath which has more grip, hence causing the clip to be held in place. Have a look inside the seal, if its damaged get a new one before you end up snapping your green regulator clip and causing the glass to crash to the floor. Costs sod all to have a look about your local scrappy Thumbs up
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 28th Jun 2011 at 00:54
danposs86
Cheers for the info, will have a look tomorrow. Also don't need excuses to go scouting around a scrap yard Wink
danposs86's GTi-6
Posted 28th Jun 2011 at 02:29
jimbamboon
My passenger window dropped to the bottom of the door about 2 hours ago. Pulled off the door card and the rubber bung that goes through the glass is half broken and popped off the green regulator, stuck it all back together for now, can you get that little rubber gromit from peugeot?
clicky code for my benefit
Posted 28th Jun 2011 at 04:48
sharvey44
The grey window clip is part number 9227 23.
The rubber bung (incl spring clip) is part number 9227 39.
Both available from Pug stealers...
Ph2.5 Nile - Slowly trying to de-East London it and restore to former glory...
Built on the 9 Febuary 1999 - Tuesday's car..is full of pace? Wink
Currently looking slightly molested due to some c*nt trying to get into it.. Sad
According to the forum Social Worker, because I work in IT, I am socially retarted..
Posted 28th Jun 2011 at 17:42
pebbles167
Only a quid at most iirc, my dealership even had them in stock!
2008 BMW K1200R
Posted 29th Jun 2011 at 00:35
