Have a problem,after replacing standard brakes with brembos(Calipers),i needed to put distance 2cm because to big ET of my Kei racing wheels that i bought with car...screws that i have is torx and goes direct into hole in the wheel.As you can assume,now i need 2cm longer screw,same type,because wheel hole. i bought standard version screw but cant go into holes on wheels,2 goes,but other 2 i cant..screws that i need is with cone, M12 x 1,25,so any suggestion will be good,hope you understand,i can attach pictures if needed
edit: this is wheel,now are only nuts but iam not satisfied with it,as i described,cant normally screw 2 nuts,but other 2 i can..
and old screw,i need screws like this,but 2cm longer
406 coupe 2.0
komer
