Author Subject: Is this a tapper?
405gti6
or just injectors.
Engine sat for at least 1,5 year.
http://imageshack.us/clip/my-videos/848/8so.mp4/
XU10J4RS powered 405 Big grin.
Posted 26th Jun 2011 at 23:24
aaron6
I would say so. You have two noises going on. The fast ticking will be the injectors but the slower tap is most likely a valve.
However, You say its been stood? Have you since changed the oil? Because when my oil get near the point of change it gets a lifter tap for the first 3-4 mins then quietens down. Have you run it for long to see if it goes?
Posted 26th Jun 2011 at 23:57
405gti6
Got fresh oil in it. Castrol something. And its been ran for some now, not on a highway though.
Far as I know its never snapped a belt...
Posted 27th Jun 2011 at 00:31
aaron6
Maybe try some whynns lifter cleaner. Might just be a sticky lifter. A bent valve and dodgey lifter sound the same in my experiance and iv had both. Hope it aint too much matey.Smile
Posted 27th Jun 2011 at 00:58
masekwm
I've read about "tapper" engines, but is it bad for the engine? Would the engine be down on power? What effect on the engine is there?
Posted 27th Jun 2011 at 01:03
1.6306
it is said that if your valve clearances are adjusted properly you can experience a very slight loss of power but not always, if you're going to adjust the clearances make sure you have the write gap for the inlet and outlet valves if there not enough gap it if possible that the valve could burn out, just get a good feeler gauge and a Haynes manual or auto-data
Posted 27th Jun 2011 at 04:08
405gti6
Clearances are adjusted by hydraulic tappets...
Posted 27th Jun 2011 at 11:57
paulvancraen
It's always hard to hear if it's a tapper from a video...
Have you driven it hard yet? That should normally shake the lifters a bit and make them not tap anymore. If it still taps, throw in the cleaner like aaron6 says and follow the instructions. After the cleaner, refresh the oil.
If it still taps after this you could try to take the lifters out and clean them (taking them apart), but you might as well take the head of and check everything else while ur at it...
Posted 27th Jun 2011 at 15:04
aaron6
The tapping itself is not bad for the engine you shouldn't lose any noticeable poke but eventually the head of the valve could snap off and smash the lot to prices. There's a photo of one that had done it somewhere on here but i can't remember where. Could also be a loose plug. Can make the same noise. Worth a look but 9 times out of 10 it ain't that. Smile
Posted 27th Jun 2011 at 18:18
