Had a knock or rattle from the front of the car ever since i bought it. Originating from the drivers side wheel area.
During my ownership it has had the following up front-
-New Eibach springs
-New Bilstein B4 dampners
-New topmounts
-New droplinks
-New ball joints
-New track rod ends
Just before i bought it, it supposedly had new wishbones too.
This knock makes itselt apparant when at low speed over uneven ground and is a rattle like wheel bolts being loose.
Its p*ssing me off a treat as its never been right.
Everytime ive had the car in the air taking pressure off the struts (whilst having parts fitted) and gotten it back it drives without this knock and i think 'yay its fixed it', only for it to come back again and again!!!!!!!!
Any ideas on that one?
Rattle number 2:
This one has only made itself apparant in the last week or two. It feels to me like when i am coming in fast to a roundabout and break strongly that two pieces of metal (a joint maybe) is pulling apart and slapping back together again. You can feel this through the pedals and feels connected to the suspension somehow. It also makes this knock/feel when i am hammering it from 1st to 2nd and upto 3rd. Generally under excessive torque.
In the last month or so ive had replaced at carls
-wishbone p bushes
Which were f*cked and i had hoped that that would sort knock number 1. But as before the knock has come back almost the next day after having these fitted.
I have thought engine mounts for knock number two and have done that whole 'keep handbrake on and engage gear slightly and rev engine' to check for excessive movement. The engine moves but not a huge amount. Mounts look intact but ive not looked extensively at them.
I have also been under the car on both sides under the wheels and tightened every bolt and nut i can find. Again no improvement....
Im most concerned about the number 2 knock as it really feels like something dangerous is going on.
Any ideas welcomed? Really losing the will to keep throwing cash at this thing....i just wana drive a smooth and tight front end - like it should be its had almost everything replaced!
Sorry for the essay but has anyone any suggestions?
Edit; its also had passenger side driveshaft replaced with a HDI driveshaft as the original had a split in the cv gaiter. This seems fine and abs works no problem.
honestly3k
