Author Subject: o/s front positive camber
luxman
hi, im new here and have just bought a 2000 306 1.4, as the tital says im having problems with the o/s front suspension, the car didnt handle right when i bought it so i got the 4 wheel alignment checked, long story short, ive fitted a new o/s wishbone (non genunine), and fitted a second hand hub and strut. got alignment checked this morning and they said its still the same. where do i go from here? thanks for any advice
Posted 25th Jun 2011 at 20:11
Sounds like the subframe could be bent ?
Posted 25th Jun 2011 at 20:20
luxman
its kinda the only thing left. But the thing is that ive done loads of measurements on the subframe and everything checks out, i was just wondering does anyone have any specs for body measurements to see if the chassis is bent, out of a matter of intrest, what is the distance between the front top shocks on other cars?
Posted 25th Jun 2011 at 21:27
wrong balljoint is a possibility, non pas are shorter and give positive camber on a pas car
Posted 26th Jun 2011 at 00:14
luxman
i was hoping to hear something like that, the new wishbone i fitted isnt genuine and the ball joint is rivited into the wishbone rather than bolted like the oe equiptment. ill try a wishbone and let you know how i get on, thanks for that
Posted 26th Jun 2011 at 00:25
cwspellowe
just drill the balljoint out and fit a balljoint for a pas car
Bye bye Sundance Kid Sad
Posted 26th Jun 2011 at 03:08
luxman
ive changed the ball joint and after an alignment check its still the same. I think im now screwed
Posted 30th Jun 2011 at 02:22
cwspellowe
It's definitely a ball joint for a PAS car, aye?
Only other thing I think it could be then is it's taken a bump. New wishbone and ball joint should have cured it...
Posted 30th Jun 2011 at 02:41
