Author Subject: changing starter motor
sparko
went to change the starter motor and the only way i can see of doing it is by removing the intake manifold. looked at the faq on it an thats easy enough but i take it you'd have to remove the air intake on the right hand side to completly remove it? or can you just move the manifold slightly to get access?
when i turn the key it just clicks. battery reads 12.4v so i take it it is the starter motor?
any help would be greatly apreciated guys Hmm
Cherry Red - Phase 1 Restoration
She's alive again Smile
Posted 24th Jun 2011 at 22:34
springs
take the manifold off. you can leave the airbox in place but just have to remove the pipes next to it.
Did mine recently as i had a similar issue.
If you can get to the starter motor you should see next to where the terminal for the main battery connector is another terminal. Stick +12v from a jump lead etc and see if it turns.. if so then sounds like the solenoid inside had died.
Posted 25th Jun 2011 at 02:37
tvrfan007
It's been a while since I looked at a standard manifold but can it not be done from below?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 25th Jun 2011 at 04:01
sparko
no chance. dont have girl arms
Posted 25th Jun 2011 at 14:35
sparko
got it done but f*ck me the allen key bolts on the starter are a b*tch to get out. starts just by key now, delighted
Posted 25th Jun 2011 at 22:36
