I bought a ’98 black 306 GTI a few weeks ago and its been in the garage pretty much ever since. It drove fine on the test drive and for a few days after I bought it, then...
First the engine misfired slightly while driving, then the starter motor began to turnover. I switched the engine off, popped the bonnet to have a look and the engine tried to start itself without a key in the ignition!
I (perhaps wrongly0 tried to get the car back to a garage and on the way lights were flashing and going out on the dashboard then all the dials failed except for the fuel gauge. There was also a smell of electrics burning.
The garage seemed to think this was a just a faulty ignition barrel. They put a second hand one in and replaced the starter motor ( as it had burned out). Apparently the induction kit air filter was rubbing on part of the wiring loom so this was moved and any damaged wires replaced.
A day after picking up the car, the same thing happened again. I’ve taken it back to the garage and they have replaced the starter motor again and are talking about re-fitting a standard air filter.
I’m thinking this is more a job for an electrician or dealership? Has anyone heard of this problem? I spoke to someone today who had an old Peugeot start itself and set on fire in a car park!
Any advice would be great, thanks
dunc707
