cheers
| Author | Subject: bonnet stuck closed |
shutie
Senior User Location: Cunningsburgh, Shetland Registered: 01 Feb 2008 Posts: 509 Status: Offline |
I have searched for other problems like this but what is the easiest way to open the bonnet apart from using the usual handle as the cable has somehow detached...? ![]() cheers |
fozzy_255
Senior User Location: portsmouth/Folkestone Registered: 30 Dec 2007 Posts: 677 Status: Offline |
Stick your hand up from underneath car in-between radiator and bumper and pull what the wire would be attached to |
shutie
fozzy_255 wrote: Stick your hand up from underneath car in-between radiator and bumper and pull what the wire would be attached to i did try that but it was too tight for my arm? |
fozzy_255
If there is any cable left just pull on it, it mught be easier to get to. Im afraid thats the only easy way. well without taking the bumper off that is |
cwspellowe
Seasoned Pro Location: Calderbank Registered: 19 Jul 2009 Posts: 6,496 Status: Offline |
Smash the grille up and undo the two bolts holding the catch on ![]() ________________________________________ Bye bye Sundance Kid |
not sure if its possible on a Rallye, but on the early TD's you can reach up through the engine bay to behind/above the r/h headlamp and tug on the wire where it has a Joiner.Could always remove the bumper and fish about under the grille, or break the grille. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
shutie
thanks guys, i will have a look around the headlight, i wasnt entirely sure where the cable ran. Might just have to take the bumper off then. |
cwspellowe
It's clipped up inside the slam panel and then along the wing ________________________________________ Bye bye Sundance Kid |
mattgti6phase2
Seasoned Pro Location: inside my 6 abusing the tarmac!! Registered: 16 Jul 2010 Posts: 2,371 Status: Offline |
Sounds to me like the the clip that holds it into the slam panel has broke hence why it's slack. The actual cable should still be in the mechanism.Cable tie the clip into position and job done. As for getting at the cable I detached mine from the leaver inside and pulled it hard then it released. ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
shutie
mattgti6phase2 wrote: Sounds to me like the the clip that holds it into the slam panel has broke hence why it's slack. The actual cable should still be in the mechanism. Cable tie the clip into position and job done. As for getting at the cable I detached mine from the leaver inside and pulled it hard then it released. the release under the steering wheel was opened fully with no give whatsoever, i stuck it down to 'my' mechanic who has just managed to get it opened this morning without taking off or breaking anything thankfully. I will speak to him later to find out how he managed it. But thankfully after that is fixed the rallye is now nearly fixed after her little missanter in a steel road barrier (6 months ago) |
russbez
haha woops ![]() emm prob not best post how he done it on public forum ![]() glad to hear you got it sorted, good luck replacing the cable if its snapped, mine was a total b*tch ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
shutie
russbez wrote: haha woops ![]() emm prob not best post how he done it on public forum ![]() glad to hear you got it sorted, good luck replacing the cable if its snapped, mine was a total b*tch dont say that..... although... i wont have to work with it |
