Author Subject: Starter motor
sparko
will a diesel starter motor be better than a standard 6 one?
Cherry Red - Phase 1 Restoration
She's alive again Smile
Posted 20th Jun 2011 at 23:59
WHy ?
Posted 21st Jun 2011 at 00:03
Think they are slightly bigger ?
Not sure why you would need one ?
Posted 21st Jun 2011 at 00:04
sparko
not turning over right. as if its a battery drain but i've checked an its sittin at 20mA an the bat is fine. altenator works as it reads 14.4 when runnin. reaths are tight an clean. can only think starter motoe. had a look through the forum and others recommend a diesel as its used to turn over higher. just seekin out options for the weekend. wanna correct it asap. gettin on my nerves.
Posted 21st Jun 2011 at 00:09
sparko
earths not reaths.
Posted 21st Jun 2011 at 00:10
slap a diesel one on then
Ball ache to fit though Whistle
Posted 21st Jun 2011 at 00:12
sparko
reckon a standard one would do the job? i'd shy away from the diesel if it'll be a headache. just tryin to get options. she's tryin my patience a little
Posted 21st Jun 2011 at 00:15
I have a feeling there is an issue with engagement on the ring gear with diesel starters. PM Rich_W, he will know for sure as he has flywheels manufactured Wink
Posted 21st Jun 2011 at 00:18
sparko
cheers i'll do that. gonna pick up a regular starter at the weekend an see if it helps. if not then f*ck knows. i'll look into the diesel option. feel like she's fighting me all the way....
Posted 21st Jun 2011 at 00:22
c_j_m
Diesel one will be fine, the hdi guys use the 6 flywheel on there cars for a dtub clutch swap.
Posted 21st Jun 2011 at 00:30
sparko
so u reckon a straight swap over would work?
Posted 21st Jun 2011 at 00:32
c_j_m
Yep. All XU ones fit all XU engines.
IIRC a while back rich had some issues with the flywheels and he said to use the 1.9DT starters to help prevent the issue.
Posted 21st Jun 2011 at 00:36
sparko
i'll pick both up an try them out. see which works better
Posted 21st Jun 2011 at 00:40
