Author Subject: Head gasket symptoms
gota6again
Evening chaps,
What are the symptoms of a head gasket dying?
I think something is SERIOUSLY wrong with mine.
The temp went all the way to red, the fans were on high speed and the interior heating was blowing cold.
Also, after searching, mine is doing the misfire on cold starts Sad
Posted 20th Jun 2011 at 23:53
kit
Is it running on all cylinders? Check for obvious symptoms such as oil in coolant, mayo type sludge in oil filler/dipstick, white smoke from exhaust. Also leave the car overnight and open the radiator cap, if there is built up pressure from overnight the HG is a goner.
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 21st Jun 2011 at 00:01
gota6again
As far as I can tell it's running on all cylinders, it pulls well and seems ok in that respect. I had a look for mayo and there was nothing.
How likely is an airlock? Do they just happen randomly?
No hot air usually means air lock ?
Miss fire on start up means something in the bores ? usually water ?
good excuse to have the head off and get a nice worked head back on with cams Wink
Posted 21st Jun 2011 at 00:02
gota6again
Or get a ready built engine.....oh wait its gone Sad
But in all seriousness, would it be cheaper just to replace the engine with a known working one?
Posted 21st Jun 2011 at 00:06
mattgti6phase2
+1 for airlock.
let her run up and open the bleed points if no water then most likely an airlock and will need bleeding. maybe check the stat as well, if thats not opening then that will cause over heating issues.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 21st Jun 2011 at 00:26
gota6again
Will look at bleeding it, hopefully it's nothing but the horror stories really do shit you up with these things!
Posted 21st Jun 2011 at 00:27
mattgti6phase2
they certainly do. but as you have said there are no mayo signs which is always good. to check the missfire unplug the injectors one by one and which ever one doesnt change the engine note is the one at fault.
good luck.
5 x a 306 owner!
Posted 21st Jun 2011 at 01:57
gota6again
good luck.
To be honest the misfire sounds like the coil pack, but the overheating really got me, hopefully a bleed and maybe a new rad cap will get her going again.
Posted 21st Jun 2011 at 02:02
ryangti6
Sounds like being low on water symptoms to me.
Check and bleed it then keep an eye on it, these engines have quite a habit of not mixing the oil and water especially in the early stages of failure.
Hopefully it was just a bit low and you have got away with it but also have a good check for leaks after you have finished bleeding it all.
Ryan
Posted 21st Jun 2011 at 02:15
gota6again
Cheers Ryan, will look at that too. Topped up last night and it was looking ok, but I suppose anything can (and usually does) happen.
Posted 21st Jun 2011 at 02:17
ryangti6
Is the heater okay now then or still cold?
Definitly bleed it through asap, if it was low or had an airlock when you added the water the rad will only take a bit of water without you opening the rad bleed point. It could easily lead you to think it was topped up enough when there is actually a lot of air in the system.
Ryan
Posted 21st Jun 2011 at 02:23
gota6again
I haven't checked, got home and left the car LOL
I'll have a quick look if it stops raining.
Posted 21st Jun 2011 at 02:25
gota6again
HG gone, but will be she will be re-born soonish.
Posted 21st Jun 2011 at 18:27
mattgti6phase2
Deffo? Are you sure?
5 x a 306 owner!
Posted 21st Jun 2011 at 20:48
gota6again
Yup, spoke to Deepak off of here and explained the symptoms plus I few more that I discovered last night, one being the stench of petrol from the rad filler, the pressure in the rad and then this morning the car spluttered and died. Just need to source an engine and she'll be back.
Posted 21st Jun 2011 at 22:51
Rich E Forum Admin
Why not just change the gasket? It would be cheaper and easier than changing the engine.
Posted 21st Jun 2011 at 23:00
gota6again
I had a chat with Deepak, the issue I have is that the head on mine has already been skimmed so I can't really afford to have it skimmed again, unless one of the wise chaps here can suggest a thicker gasket that would compensate for the skim? I would prefer mine to be repaired as it would have new shiney bits and I'd know what has been done - also eyeing up some cams LOL as it's the perfect opportunity.
Posted 21st Jun 2011 at 23:04
Rich E Forum Admin
Unless it was skimmed right to the limit before it should be fine to be skimmed again. Unless it's been massively overheated only a very small amount of material usually needs to be removed to regain a flat surface.
Posted 21st Jun 2011 at 23:10
gota6again
Ah ok, I didn't know that. Is there an option to have a thicker gasket though? For example the ones Rich at Lynx does? I'm not too clued up with uprated parts.
Posted 21st Jun 2011 at 23:13
720puggti
Hi Dee,
Repairing the head is an option, I'm not too up on the exact figures, but there is a maximum permissable amount you can remove. So it would involve removing the head and haing it's height measured along with flatness at the engineers. The only problem comes when it is measured and reads out of limits, everything turns into a waste of time...
It's all up to you mate, a repair may be possible, but replacing the engine is also an option.
Deepak
Deepak Gohil
Posted 21st Jun 2011 at 23:20
gota6again
Hey Deepak, I'm totally open to the various options, I'm happy for you to suggest the best options. I would rather have mine repaired as like you said earlier it would have new items and I'd know the exact history of it. I'm waiting on a reply on how much an engine will be and go from there. If you're happy to measure up and advise that'd be great.
Posted 21st Jun 2011 at 23:53
