Author Subject: Clutch Peddle Problem
cornish_pug
I've got a problem with my clutch peddle. It feels loose to press the clutch then it stiffens up about half way down. When I release it, it comes up fine till again about half way up it stops and I then have to place my foot behind the peddle & flick it back up with my foot. It seems to be getting worse though, as in my biting point is getting lower. It's almost as if the cable at the peddle end needs adjustment. Does anyone know how to cure this? It's on a HDi btw.
Team Diesel
Posted 20th Jun 2011 at 04:46
New cable and prob new clutch kit?
Whats the mileage on the clutch and cable ?
Posted 20th Jun 2011 at 04:51
cornish_pug
Car has done 118k now, but not sure the age of the clutch or cable.
Team Diesel
Posted 20th Jun 2011 at 11:27
Clutch cable first because it's cheap. If that doesn't fix it, bushes, clutch etc.
Posted 20th Jun 2011 at 13:20
krisb
As a quick fix, you could just move the large black part of the clutch cable further towards the gearbox half an inch. You'll find it clipped to the subframe under the car.
www.krisb.co.uk
Posted 20th Jun 2011 at 23:57
Or you could just treat the car to a nice cable and spanking new clutch - it will feel like a different car - trust me its money well spent Wink
Posted 20th Jun 2011 at 23:59
cornish_pug
Looks like a small gaiter, yes?
Team Diesel
Posted 21st Jun 2011 at 00:40
krisb
Thats the one, there's no harm in getting every last bit from the clutch cable Smile
www.krisb.co.uk
Posted 21st Jun 2011 at 00:42
Mate honestly if you're going to that kind of trouble, just replace the cable Yes
Posted 21st Jun 2011 at 01:07
cornish_pug
Yeah i purpose, but it's a short term cure until pay day
Team Diesel
Posted 21st Jun 2011 at 02:28
cornish_pug
Just seen the two FAQ's for this job & it looks ok ish to do.
One question though! Is the process exactly the same on the 306 HDi? Not sure if the aircon pipes run in the same place as on the 6 Wink
Team Diesel
Posted 24th Jun 2011 at 23:18
cornish_pug
Changed the cable today & my god was it a b**ch Angry i followed the FAQ guide but being a HDi i had to remote the bottom engine mount bolt because the pipe from the turbo was in the way of getting the cable out from under the car.
But in the end it was worth the cuts & blood LOL
Team Diesel
Posted 27th Jun 2011 at 00:25
I'd of had the box off and done that at the same time Wink
Posted 27th Jun 2011 at 00:34
My clutch cable went on my way to germany a few weeks ago, sounds a little bit similar to this, the biting point was moving all over the place until eventually i couldnt disengage it at all.
I reckon the auto adjuster went.
Luckily i had a spare cable on me so swapped the cables over on the belgian motorway hard shoulder just after a heavy shower Doh LOL
Posted 28th Jun 2011 at 00:01
cornish_pug
Don't think the gromit has sealed in the bulkhead properly Doh because i can hear engine noise down by the peddles
Team Diesel
Posted 28th Jun 2011 at 00:55
dudz-gti6
i think i have a simalar problem as i have nothin on the clutch til half way down but it still goes into gear properly. i got told my cable is fine but its the bar that links the box n clutch together is ceasing up or gettin rusty or something like that n should change the clutch at the same time as they gotta take the box off. any got any other ideas to what it could be.
Wanted: Ph3 crystal headlights, Upper and Lower Strut Brace, 60mm lowering springs, de-badged bonnet and laguna splitter.
Posted 29th Jun 2011 at 23:39
cornish_pug
That was an identical symptom to mine, it's fine now i've changed the cable. The auto adjuster in the cable had got water in it which didn't do it any good.
Team Diesel
Posted 30th Jun 2011 at 00:31
dudz-gti6
i will try the cheaper option first then (cable) but if thats doesnt help short term the i will change the clutch but thanks for the help
Posted 30th Jun 2011 at 01:40
