Author Subject: 205 gti6 reving issue
allsmiles
hi folks my 205 gti6 is having rev/idling issues at the min
basicly the car does idle at 1k rpm nicely but as soon as you start driving the revs would stay at 2500 rpm when you change gear and it would continually stay at 2500 rpm until the car comes to a complete stand still where it would idle at 1000 rpm, basicly the revs dont drop when i press the clutch down whilst on the move
sometimes the car will behave itself properly but not for very long
i have changed the throttle body which is running a bit better than my old one but its still not quite right, and im about to buy another throttle body to try and cure it but i thought i would come ask on here first
any ideas folks, thanks in advance
205 gti6 now sold up, but gonna stick around and see whats what Smile
Posted 16th Jun 2011 at 19:22
24seven
The VTS engine in my 309 does this, and did while it was in the VTS. I suspect it's down to the MAP sensor or perhaps the ICV sticking. Thinking bout it it could be down to a small air leak that is being metered, so around the ICV perhaps.
Posted 16th Jun 2011 at 20:34
mikeygulley
I had this problem a while ago (I have the VTS in a 205) and it was the ICV. But defo check for air leaks too.
PSCUK Devon & Cornwall Group Leader
devon@pscuk.net or cornwall@pscuk.net
Next meet: TBA
Facebook: click here
Your chances are slim and none.......slim just left!
Posted 17th Jun 2011 at 17:13
spiky
give the throttle pedal a tap from behind with your foot when it's at 2500
if it drops to 1000 then either the cable or throttle body needs a clean
if now, then air leak or ISC
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 17th Jun 2011 at 17:23
allsmiles
thanks for posting folks, today i took the ICV off and cleaned it with wd40 and it was still idling wrong
theres a gti6 breaking near me and i am off to buy a ICV and TPS off him so i can rule those out
by the way whats a ISC?
im off to work now so i will reply laters
Posted 17th Jun 2011 at 21:51
24seven
Did you keep your old TPS when you changed the throttle body over?
Posted 17th Jun 2011 at 23:30
jonnie205
The fault will be that the loom has not been wired in properly resulting in the icv not getting 12v, the car will run but there is an extra wire to power up the icv
Posted 18th Jun 2011 at 02:00
24seven
This was happening on my engine while it was in the xsara on on a different loom/ECU. Plus Spiky had this loom running in his 205 GTi6 and afaik he didn't have issues. I'm convinced it's a sensor issue as the car does eventually idle perfectly and will pull away without needing any throttle input, so the ICV must be working ok.
Posted 18th Jun 2011 at 02:33
allsmiles
i havent checked as it was a mate who changed the throttle body over but i did tell him to replace the whole entire throttle body over using all the stuff that was on the throttle body i picked up, to be honest i didnt even check what was on the throttle body lol! but the tps isnt that expensive so i may just get a new one anyway
im having the tps and icv off a local gti6 breaking so i will report back when i have swapped them over
Posted 18th Jun 2011 at 05:37
24seven
Chances are the TPS was swapped with the TB then. Get a MAP sensor as well - check if you have a square or a round plug type sensor first, the plugs are different shapes and not interchangeable.
Posted 18th Jun 2011 at 06:21
spiky
I vert much doubt that, as the wiring to the icv isn't touched when these looms are altered
Will only be 1 of the 3 things in my post above
MY YouTube Videos'
Posted 18th Jun 2011 at 12:51
spiky
Check your throttle body is actually closing fully
MY YouTube Videos'
Posted 18th Jun 2011 at 12:53
allsmiles
problem solved
tps was the problem Big grin
Posted 19th Jun 2011 at 15:09
spiky
Nice one Smile
MY YouTube Videos'
Posted 19th Jun 2011 at 15:32
