Author Subject: Brakes feel like a sponge
poogiepug1
Hey all
My brakes were fine up till a few days ago. They feel like sponge and i have to pump them couple of times to stop!! The brake pedal pretty much goes to the floor and my ABS is no longer working (tested it a few times) Could it be the ABS pump? My car is phase 2.
I know it cant be the discs or pads as they have been done not to long ago.
Would appreciate some help. ThanksSmile
Posted 13th Jun 2011 at 03:38
mr swampy s16
**BAD SELLER**
Sounds like a seal in the master cylinder has gone.
Not realy advisable to drive the car like that.
Posted 13th Jun 2011 at 03:48
poogiepug1
Ok. Is that a cheap fix?
Posted 13th Jun 2011 at 04:06
mr swampy s16
**BAD SELLER**
Probs around the £120 mark at a garge, not sure how much a new mc costs.
Easy to fit, hard part is bleeding the brakes afterwards
Posted 13th Jun 2011 at 04:11
poogiepug1
ok thanks, i will take it to a garage tomorrow. Bloody car
Posted 13th Jun 2011 at 04:37
paul_13
Is there any fluid leaking from under the car/bonnet for starters?
Check your flexi's front and rear. Check the inside of the wheels for brake fluid where it's dripped down the caliper/disc. Check all the flexis are tight going into the caliper, may of come loose.
Is there fluid in the reservoir?
I've had a set of flexis go porous before, brake fluids leaking through the flexi line. No splits
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 13th Jun 2011 at 04:42
