Author Subject: Clutch
ryans6
I posted a comment on here a week or so ago which turned out to be the clutch arm being seized.
My problem has vastley improved but i have come to the conclusion i need to replace the clutch at some point.
Can any one tell me which clutch (make) to go for and is it worth replacing the cable the same time.
BLACK 6
Posted 7th Jun 2011 at 23:48
Oe valeo clutch kit and gen pug cable
New drive shaft seals as well
Bit of an arse to fit the cable on six though Dry
Posted 7th Jun 2011 at 23:49
dont forget the clutch shaft bushes too.
Posted 7th Jun 2011 at 23:52
ryans6
I replaced the left hand driveshaft seal recently hoping this would cure my problem, thinking gear oil was low.
As for the cable is it the air con pipes which get in your way? as myne leaks gas very slowly so im thinking just abuse/bend the pipes?
BLACK 6
Posted 7th Jun 2011 at 23:56
ryans6
does the clutch bushes come in the kit?
BLACK 6
No they don't, sure someone on here can post up the part numbers
Posted 8th Jun 2011 at 00:07
ryans6
Thanks for your help Big grin
BLACK 6
Posted 8th Jun 2011 at 00:20
