I'm after a bit of info on the engines. I have a 2.0 xsi with a good engine and i was wondering if i could take the engine block from my xsi and put my head off my gti-6 on it.THen drop it back in my gti-6
any help would be grateful
| Author | Subject: cracked block!!! |
scotty27
Newbie Location: cannock Registered: 04 Jun 2011 Posts: 4 Status: Offline |
hi guys this my first post on here has i never knew about the site before until i have been searching for parts for my gti-6.I'm after a bit of info on the engines. I have a 2.0 xsi with a good engine and i was wondering if i could take the engine block from my xsi and put my head off my gti-6 on it.THen drop it back in my gti-6 any help would be grateful |
smegal
The pistons in the XSI are different so I wouldn't recommend it. The block is the same though.________________________________________ Ex SC-6Now in a Megane R26 |
scotty27
smegal wrote: The pistons in the XSI are different so I wouldn't recommend it. The block is the same though. so it will fit if i change the pistons? |
scotty27
any ideas guys??? |
Rich E
It will fit yes, but you will be down power due to the lower compression of the XSi engine.You could fit GTi pistons but it would be a lot easier to just find a GTi block. ________________________________________ Rich |
scotty27
Rich E wrote: It will fit yes, but you will be down power due to the lower compression of the XSi engine. You could fit GTi pistons but it would be a lot easier to just find a GTi block. Thanks mate, but i'm struggling to find gti one. |
smegal
Stick a thread up in the wanted section and see what comes up. You can get a whole engine for £400 ish.________________________________________ Ex SC-6Now in a Megane R26 |
cwspellowe
Seasoned Pro Location: Calderbank Registered: 19 Jul 2009 Posts: 6,496 Status: Offline |
Eddy normally has a block or three lying about________________________________________ Bye bye Sundance Kid |
ultimate 6
Banned!Location: birmingham Registered: 30 Jan 2010 Posts: 318 Status: Offline |
Got a good gti6 bottom end here you can have for £60 collected from birmingham________________________________________ Cossack grey gti 6 |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
that's not a bad price!or if you intend of re-polishing/grinding changing bearings etc I have a block you can have i just spun a bearing so the block is fine but the internals are shot! block it's self is spot on! it's in Sheffield if you want to get it? ________________________________________ Proud Member of the ASTOR Owners Club |
