Author Subject: Another Idle/Starter Issue
donny
Right i have done a search and i have got some ideas what it could be but wondering if anyone could narrow my options down....
Right, the car recently would start but have a very rough idle, spluttering alot around 1000rpm droping below and picking up. When coming upto a junction letting the revs come down, put the clutch in and the car would stall. (No issues at all while driving)
The car since i owned it (not long) didnt have a breather filter on, so put one on tonight and now the car turns over starts(ish), then cuts out?!
Dont no if this is relevent but the idle issue started a few days after a new cambelt, worked fine for a day or so then idle issues....
My thoughts are icv/stepper motor issues? is that my best place to start?
Thanks in advance Cheers
Donny
Posted 2nd Jun 2011 at 02:49
donny
Update;
Cleaned the icv tonight and re set the ecu...
Started the car, worked fine, turned off and didnt like idling so kept stalling....
Took it out for a good run and after a while didnt stall at any junctions....
On tickover at junctions the revs dont really move from 950rpm but the car is spluttering and juddering...
Has anyone any ideas what this could be?
Thanks
Donny
Posted 3rd Jun 2011 at 01:12
paul_13
Test your alternator voltage when it's running should be 14.4v, also rev it and check aswell.
Other than that check all the earth points
Or could be a coilpack!?
Double check your timing for piece of mind, what bottom pulley did he use to time it up?
Is your cam sensor still plugged in? could of been disturbed from the cambelt change.
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 3rd Jun 2011 at 01:34
donny
I will check them tomorrow thanks for that!
Im abit worried about the cam timing?!?! couldnt that cause some serious issues/problems?!
Donny,
Posted 3rd Jun 2011 at 01:39
paul_13
Yep, but I think it would be obvious by now if it was wrong. Loads of tapping/banging and 16 bent valves.
Who did the timing?
Posted 3rd Jun 2011 at 01:54
donny
Well there is not sewing machine, banging, tapping etc so hopefully/doesnt sound like it is that.....
Cam sensor could be worth a look!! May need to find someone local and change some sensors see what works and what doesnt....
Donny
Posted 3rd Jun 2011 at 02:07
paul_13
Good good.
would be worth whipping the crank sensor out and giving a clean.
When you reset the ecu did you leave all of your electrics on untill the fans kick in? I can't see it making much difference.
Posted 3rd Jun 2011 at 02:20
donny
My understanding of re-setting the ecu was disconnect battery for 15 mins or so, connect it back up and go for a drive?!?! What should i have done?
Donny,
Posted 3rd Jun 2011 at 02:23
cwspellowe
ideally you need to let the fans kick in at high speed with all the electrics turned on to set the voltage drop correctly, then go for a drive
Bye bye Sundance Kid Sad
Posted 3rd Jun 2011 at 03:03
paul_13
As the man said ^
Posted 3rd Jun 2011 at 03:06
donny
ok, i shall try again Big grin
Hope i find the problem to the rough idle too....
If anyone else has any ideas feel free to post them up Big grin
Ta, Donny
Posted 3rd Jun 2011 at 03:58
donny
Turns out to be a worn/damaged wire from the ICV!!
She idles like a beauty now,
Big grin
Posted 7th Jun 2011 at 13:40
