Author Subject: 306 rear axle
liamd2011
i got a t reg 306 1.9 dturbo wanted to put gti axle on but wondering because alloys on my dturbo are 14 inch they wont fit on the gti axle so will i have to buy new 15 inch alloys then differnt discs for front so the alloys fit on front? also if i need new discs on front to fit bigger alloys what will i need eg new brake callipers pads.
any help would be appreciated cheers
ldoidge
Posted 29th May 2011 at 23:12
fozzy_255
14s do fit, is just front gti brakes that need 15s
Posted 29th May 2011 at 23:26
liamd2011
surely the back if it has gti discs will need 15's? im sorry if im being a retard i never have owned a 306 gti the inssurance dont like it if ur 17.
ldoidge
Posted 29th May 2011 at 23:33
fozzy_255
The 1.8 petrols and HDis ph3 both came with the same rear brakes as a gti and 14's fit them, and i put 14s on the back of the gtis when im braking them so i can assure you 14s fit.
Posted 29th May 2011 at 23:38
liamd2011
ok thanks so much Smile
ldoidge
Posted 30th May 2011 at 00:16
306weasel
Quite correct, all 306's with rear disc brakes have identical size of disc/calliper regardless of engine size. The only thing that differs slightly is the calliper piston diameter but that obviously won't affect wheel fitment.
Car#1 306 HDi Meridian 5door, 133Bhp, 225lb.ft Ecosse R/R 20/3/05
Car#2 306 1.4 3door track car with Gti6 power. 167Bhp, 134lb.ft Ecosse R/R 21/10/07
Car#3 Grand Scenic 1.9DCi (Expanding!) family mover.
Posted 30th May 2011 at 02:28
liamd2011
cool but when i bought discs for front i gave them the reg they asked if it was abs which it is so i said yes. got home discs would fit but the 14 inch wheels wouldnt fit on to them went back they said that cant be try these which were non abs apparently and they fitted. they told me abs should have 15 inch wheels? and that peugeot are somtimes like that put what ever is lying around on. can you clear this up. it confused me that why i was woried about them not fitting on the axle.
ldoidge
Posted 30th May 2011 at 03:56
306weasel
For the front there are 3 possible disc sizes:
247mm solid (basic Ph1 models only)
247mm vented
266mm vented
283mm vented (gti6/rallye only, need min 15" wheel)
Also ABS/nonABS hubs are possible depending on model.
Within each disc size there are also different possible makes of calliper with different pad shapes Lucas/Bosch/ATE
Posted 30th May 2011 at 16:33
liamd2011
thankyou that cleared that up.
ldoidge
Posted 30th May 2011 at 20:14
