Author Subject: Intermittent Misfire
mike_306
Afternoon all, having recently bought a 6' i knew that there would be plenty of work needed. However i cant seem to trace a fairly intermittent/odd misfire. It only ever seems to happen under heavy loads, usually between 2-3000rpm. But will then pull cleanly threw the rev range until towards the top end it will again start to miss slightly.
So far the plugs, coil packs and CTS have been replaced and it hasnt changed the fault at all. The car has been compression tested and were all fine. The only other thing i have noticed is that the ICV is not quiet right (low idle from cold/high idle on times) could this be a part of my fault?
Any ideas welcomes as no doubt one of you guys will have come accross something sumular Smile
Team : Sold my 6 Sad
Posted 27th May 2011 at 20:18
mike_306
Just as an additional peice of info, i unplugged the lambda and the car ran exactly the same. So i really dont no where to go with it now.. Gotta love french cars eh! Big grin
Posted 28th May 2011 at 00:17
george23
If you find the answer to this, il be interested to know as mines been doing the same thing! does it seem to miss at idle at all? just every now and then it will miss but then fine!?
Posted 29th May 2011 at 04:51
Could be the lambda, but it doesn't use it on WOT (wide open throttle - ie flat out).
Fuel filter or MAP sensor ever been changed? Could be the ICV if you know its got problems, but dunno why it'd be affecting the running rather than just the idle.
Posted 29th May 2011 at 14:24
mike_306
Car idles and drives just fine, except under heavy loads. Even then it doesnt feel like a heavy misfire, it will still pull threw the rev range, the most noticable thing is the shaky gear stick/massage seats LOL
Hadnt even thought of the fuel filter so good shout Smile will get one ordered tuesday and see where it goes.
This might sound really daft, but being that the car doesnt put the light on. Is it possible that the car could still need sensors (ie map/lambda etc)
Posted 29th May 2011 at 23:55
little azz
i have a 306 doing the same thing but mine just a misfire on idle wich is ther all the time on idle and dont want to start some times so i just orderd new plugs coils if they dont fix it what do you think i shud buy next
Posted 31st May 2011 at 03:11
brownboy
a spell checker !!Wink
Posted 31st May 2011 at 03:20
mike_306
Still cant pin point this, anybody got any ideas at all, Unplugged lambda and reset ecu, no different at all
Posted 8th Jun 2011 at 01:13
donny
Little azz sounds like your idle control (icv) mine was a faulty wire connecting to the icv unit and had the same problems as you,
Mike_306 could it be fuel pump? map sensor? im not the most mechanical of minded people, i just had the same issues as little azz....
Im sure someone on here will sort you out Big grin
Posted 8th Jun 2011 at 01:51
