Author Subject: idling when air-con switch on
cescnathan
My 6 has idling problem and almost misfire when i step on the clutch to change gear to N in slow speed.
It happens when air-con was switch on.
Sensors - MAP, ICV, lamda, coolant temp ECU, coolant temp Gauge & cooling fan switch have been replaced still no joy Dunno
Any idea? Erm?
Posted 25th May 2011 at 20:53
The idle speed should increase when air-con is on.
Posted 25th May 2011 at 16:51
cescnathan
yes, it increase when air-con on, idle swing and stall almost misfire when i change gear in low speed.
idle is fine when driving in air-con off.
Posted 25th May 2011 at 20:56
cescnathan
Anyone got an idea?
Posted 19th Mar 2012 at 06:56
Try cleaning the ICV.
Posted 19th Mar 2012 at 07:04
cescnathan
Replaced a new ICV still no joy........
Posted 19th Mar 2012 at 13:46
When you run the air-con it puts more load on the engine.
Have a look at the lambda sensor, if this is faulty it may well not like idling or low speed when there is an increased load on the engine.
Posted 19th Mar 2012 at 14:03
Just noticed you have changed the lambda...Doh
Posted 19th Mar 2012 at 14:04
anth
air filter for the icv clean?
Posted 19th Mar 2012 at 14:44
cescnathan
Air filter has been cleaned when changing the new ICV. Erm?
Posted 20th Mar 2012 at 08:10
Try unplugging the power steering pressure sensor from the line.
The function of this component is to up the revs when it senses more load on the engine with the use of steering at idle. If you already have more load on the engine with the air-con it has been known for this component to cause random stalling issues, and this could well be the cause in your case.
Posted 20th Mar 2012 at 09:16
cescnathan
Thanks mate! I will check this out tonight. Thumbs up
Posted 21st Mar 2012 at 17:58
Thumbs up
Keep us informed. Smile
Posted 21st Mar 2012 at 20:06
I was just going to say power steering pump sensor Thumbs up
Posted 21st Mar 2012 at 20:18
cescnathan
Tried unplugging the steering pump sensor last night, idle increase a bit and swing but no stall.
will this related to clutch problem?
Posted 26th Mar 2012 at 10:30
You have a clutch problem as well? Unsure
Posted 26th Mar 2012 at 14:23
smegal
Especially given your location, I'd recommend buying a peugeot planet kt and seieng if it finds any errors.
Ex SC-6
Now in a Megane R26
Posted 26th Mar 2012 at 16:13
cescnathan
Because this problem happens when i change gear to N in slow speed..Erm?
so make me associate with clutch as well, maybe clutch arm something?? Dunno
haha!
Posted 26th Mar 2012 at 16:24
There are no electrical sensors associated to the clutch on these cars. No
If unplugging the PAS sensor has solved the idle cutting out I would say you need a new sensor. Yes
Posted 26th Mar 2012 at 16:29
cescnathan
Checked two times already and found no error code show.
Posted 26th Mar 2012 at 16:30
cescnathan
Thanks mate.... I go get a new one then~~ Thumbs up
Posted 26th Mar 2012 at 16:32
Thumbs up
Posted 26th Mar 2012 at 18:29
woody.
Mine gave up the ghost a while back and its been unplugged ever since LOL I think I'll throw a new one in for peace of mind. Where's the best place/cheapest place to get a new power steering sensor?
Posted 28th Mar 2012 at 12:16
i think i might need one of these, its like my car has no resistance to stalling sometimes and it gives up when you lift the clutch a little too far without reving a bit
Posted 28th Mar 2012 at 12:45
Pug will be the only place mate if you are looking for new. Yes
Posted 28th Mar 2012 at 12:46
