Hopefully someone will be able to offer some advice on an issue I have with my 306 XSI.
Since xmas time, I have had an intermittent problem with my engine revs whilst driving and also when idling.
Started off with the revs dropping when approaching islands, slowing down ect. It had the feel of me being in the wrong gear. Felt like an air pocket was holding the car back before clearing itself and the engine would accelerate fine.
A couple of times the revs dropped off that much, the engine stalled.
Also, when stationary, the engine would rev up to around 20000 and then drop back down to normal.
Like I said, this was intermittent. I could go days without an issue, and then it would start up again. There was no set pattern to the issue (weather, first thing in morning ect)
This went on for a few months. I had the breather pipes all cleaned and checked, made sure all were connected. I personally cleaned the stepper motor with carb cleaner.
Then finally, one day, the car would not turn over from cold. Called the RAC, who checked a load of stuff, tested a few light bulbs against some connectors, and they informed me that the Crank shaft sensor was shot.
Infact, when it was looked at by my mechanic, the sensor bracket had completely snapped off, which he found odd as he claimed it looked “snapped” off rather than wear and tear.
Due to this, the sensor so it was not sitting correctly, and this was, he felt, the problem. He replaced the sensor and all my problems went away. I had around 4-5 weeks of complete trouble free driving. Not one issue, rev drop or stalling.
Unfortunately, the old problem has come back. I took it back in, everything was checked again, diagnostic tested, but nothing showed up as being a problem. The mechanic basically said it was probably something that we would never get to the bottom of!
Can anyone add any thoughts or suggestions to what they think it could be? I’ll be honest and admit that the car has not had a full service for a few a couple of years, so the plugs, filters ect are probably well past they sell by date.
I don’t want to throw money willy nilly at the car, as I can not afford it, so any help would be much appreciated.
jediknight49
