Author Subject: oil coming out of the dip stick
maddriver9
hi guys i sold my 205 gti6 on ebay the other day and someone came to collect it to night, they were sound people and new there stuff.
it was pointed out to me that when the oil breath on the head was blocked up it was causing preasure in the crank and spitting oil out of the dip stick.
they imformed me it could be head gasket or piston rings, is this right or could it be somthing else?
178bhp 205gti6
¼ mile in 14.2
Posted 24th May 2011 at 00:58
tell them not to block the oil breather on the head and it'll be fine Thumbs up
Posted 24th May 2011 at 01:12
maddriver9
i could but is that not just ignoring the problem
178bhp 205gti6
¼ mile in 14.2
Posted 24th May 2011 at 01:14
Rich E Forum Admin
No. There wouldn't be a crankcase breather circuit if the engine didn't need it.
Posted 24th May 2011 at 01:33
maddriver9
rich e, could you explain what you me please as i dont understand
178bhp 205gti6
¼ mile in 14.2
Posted 24th May 2011 at 01:51
rallyeash
the engine makes crank pressure as it works which needs venting to the outside, if the breathers are not properly plumbed up properly or have enough flow crank pressure will build up and push the dipstick out the hole along with some oil
got any pics of your breather setup?
309 3dr K20 Type R
Posted 24th May 2011 at 02:05
maddriver9
i dont know how to up load pics so what i have is the breather on the cam cover that goes to the throttle body has been removed, the breather just vents from the head to atmospher and i have bunged up the other hole on the throttle body. i did this to stop oil vapore from entering the throttle body.
178bhp 205gti6
¼ mile in 14.2
Posted 24th May 2011 at 02:15
put it back Thumbs up
Posted 24th May 2011 at 02:51
maddriver9
i already have done but is there really a problem or is it just miss under standing?
178bhp 205gti6
¼ mile in 14.2
Posted 24th May 2011 at 03:07
Rich E Forum Admin
It's only a problem if the oil still gets spat out with the breather properly connected.
Posted 24th May 2011 at 03:16
andy306gti
As long as none of the vents are blocked then venting to atmosphere should be fine. This is how mine is any there are plenty of others in the same configuration.
Have these people already taken the car and blocked the breathers or is it blowing the dipstick in your current setup?
Posted 24th May 2011 at 03:20
maddriver9
no its been fine when i have been running it, never used oil or water. they pulled the dip stick out and blocked the oil breather and after 10 secs it would start to spit oil out. it has never done anything like this and its had some death since i bought it.
178bhp 205gti6
¼ mile in 14.2
Posted 24th May 2011 at 03:27
rallyeash
there trying to have you over, them to f*ck off Thumbs up
309 3dr K20 Type R
Posted 24th May 2011 at 03:32
maddriver9
lol so do you think they are trying to do me, they said they would ring in a few days to see what wanted to do with the car.
so is there noting to worry about
178bhp 205gti6
¼ mile in 14.2
Posted 24th May 2011 at 03:35
rallyeash
sounds like it or there genuinely thick LOL im not sure what else there expecting if there going to block the breather off.
if they offer you half the asking price or somthing then deffinatley trying to have your pants down!
309 3dr K20 Type R
Posted 24th May 2011 at 03:42
maddriver9
i thought my self that buy blocking the breather the oil presure would have to find its way out some where else like the dip stick.
178bhp 205gti6
¼ mile in 14.2
Posted 24th May 2011 at 03:49
