what cud be the cause of this ?
TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!ps3 online name : butcherboy200
dyno print out : 185.4 at the flywheel
modern warfare 2
| Author | Subject: no brake lights |
Paddy Power Turbo
Banned!Location: galway/ireland Registered: 24 Feb 2009 Posts: 628 Status: Offline |
iv looked at all the bulbs even changed 1s that looked bad checked fuse but still no lights what cud be the cause of this ? ________________________________________ TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!ps3 online name : butcherboy200 dyno print out : 185.4 at the flywheel modern warfare 2 |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
Brake switch on the pedal________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
cwspellowe
Seasoned Pro Location: Calderbank Registered: 19 Jul 2009 Posts: 6,496 Status: Offline |
Do any lights work? Under the passenger glove box there are two big plugs, a white and a brown, check they're both connected properly________________________________________ Bye bye Sundance Kid |
peetypug
Seasoned Pro Location: Spooning marksorrento205 Registered: 20 Feb 2011 Posts: 1,869 Status: Offline |
my money is on the brake light switch!i bet its burnt out ![]() ________________________________________ Cherry rallye - DOB Thursday 29/04/1999Team Rallye - the leaner, meaner, better looking sister of the GTI6 ![]() roland rat wrote: You sir either live for the 6 or have a mental retardation to still be repairing this! The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental. |
Paddy Power Turbo
cwspellowe wrote: Do any lights work? Under the passenger glove box there are two big plugs, a white and a brown, check they're both connected properly all other lights work except the brake lights is it a hard job to do the switch ? ________________________________________ TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!ps3 online name : butcherboy200 dyno print out : 185.4 at the flywheel modern warfare 2 |
seanys 306 rallye wrote: cwspellowe wrote: Do any lights work? Under the passenger glove box there are two big plugs, a white and a brown, check they're both connected properly all other lights work except the brake lights is it a hard job to do the switch ? Its not hard, but it is a complete pain in the arse - steering column needs to be dropped. Think there is an FAQ ________________________________________ Nothing to see here |
