Author Subject: help!!! im stuck with matrix change
ady347
hi, decided to do this myself, i have followed this guide completely removing all nuts and bolts mentioned. i can pull the dash about 2 inches on either side but it seems stuck, i tried lifiting and pulling too. to me it seems tight in the middle.
http://www.306gti6.com/forum/showthread.php?id=78999&page=last
Posted 21st May 2011 at 20:15
mike rallye
have you removed the wipers and the wiper motor/ there 3 screws under there
Posted 21st May 2011 at 20:57
chiefy
Can you tell whether it feels stuck nearer the top of the dash or the bottom?
My guess would be that you may have missed one of 2 screws, or maybe even both, as I had this problem the second time around. I've had a quick look through the guide your using and I didn't see them mentioned. I will now try my best to explain where they are..
The first and most likely one is bang in the middle of the dash, right at the bottom where the centre console would have been. Look up and underneath it and there should be a plastic bracket on the dash with a torx screw going through it and into the blower unit.
The second is on the passenger side of the dash, again just behind and underneath the bottom edge of the dash. Look just along from where the centre console sits again, can't remember off the top of my head but at a guess I would say 2 or 3 inches in from where the bottom edge straightens out. Torx screw again (same size I think as well), also attaches the dash to the blower unit.
I hope that helps in any way, if you have already removed them then it may just need working off, or could even be something silly like something catching on the steering column etc.
Posted 21st May 2011 at 21:42
ady347
ok, i have managed to move the dash now it was the brake switch switch cable amongst other bits. i havent removed dash completety i have pulled the passenger side out like in the picture.
i have followed every bit of the guide as best i can so i am sure i have removed everything required. i need to get the car fixed and back together as its in a bit of a mesh now lol
basically how the heck do you remove the matrix. i have absolutely no idea, i tried removing the blower motor and casing but no matter how many bolts i undo its stuck (their are some pipes going into behind the motor from engine bay) i think these are air con pipes??? i dont even know if i am removing the right bit. i can see the matrix, cant tell how the heck the pipes comes off, removed a metal clip but they seem stuck solid.
the matrix has got me really puzzled as to what i remove to get it out.
Posted 21st May 2011 at 22:31
krisb
Undo the two nuts out in the engine bay, manifold kinda level with a red washer.
Best thing to do is to break off what you can see of the matrix from the engine bay so it'll pull through much easier and release the entire housing/matrix
Once you've removed it and get back round to re-fitting, just cut the rubber gromit between the two holes. Some wd40 or washing up liquid also comes in handy for refitting.
The cut i mention... it's worth it.
www.krisb.co.uk
Posted 21st May 2011 at 22:37
ady347
yeah i undone the 2 nuts mentioned earlier. my pipes have been cut previously and bypassed so i was hoping to remove matrix from inside of car with whats left of the pipes still attached to matrix. can i do this or do i need to disconnect pipes from matrix in engine bay
the matrix is in a big housing is this hole housing supposed to pull towards me from inside car or??
am i supposed to remove the fan motor housing that the matrix housing is joined too?)
ady347 has attached the following image:
Posted 21st May 2011 at 23:01
iplay
If you are just changing the matrix or removing it undo the 2 retaining bolts on the matrix surround and just pull the matrix out without touching the rubber seals in the bulkhead. check for sixysix thread on matrix ... it might have some details here READ post #7 - this is the simple way to do it!
Posted 21st May 2011 at 23:16
krisb
Okay, now what you have gotta do is go round to the engine bay, break off the black plastic which is part of the matrix - this is so you can pull the blower motor and matrix away from the bulkhead.
Dont so much worry about taking anything else apart, just smash off the visible bits of the matrix from the outside.
www.krisb.co.uk
Posted 21st May 2011 at 23:05
krisb
Oh, and another thing to mention, DO NOT take the elbow off your new matrix. I've seen so many people get the job and it leaks after. It's not worth seperating the elbow.
www.krisb.co.uk
Posted 21st May 2011 at 23:06
ady347
so basically where the rubber pipes join the plastic elbows of matrix in engine bay, i can smash all that off?
Posted 21st May 2011 at 23:25
krisb
As long as you've removed whats left of the hoses and the fitting on the end of the hoses.
All you should have left (to smash up) are two bits of pipe poking out of the rubber gromet about an inch.
www.krisb.co.uk
Posted 22nd May 2011 at 00:36
ady347
ok, in the meantime i broke it on the inside of car and have now got out the matrix.
the plastic housing that the matrix sits in had brown dirty dried water in it, so guess it was leaking? (i dont know car history just the matrix was bypassed)
i noticed in engine bay their is a metal clip where hoses secure to matrix, i removed the clip but wondered how do i get the fitting off?
also what is the metal probe that is in the side of matrix (that you pull out) before you remove matrix from housing. mines a aircon model
thanks for help so far
Posted 22nd May 2011 at 01:19
ady347
anyone? was hoping to get this back together today
Posted 22nd May 2011 at 15:47
mike rallye
the metal prob is for the aircon models,iirc it a tempture. yes the tried brown water is most likelythe matrix leaking,just clean the inside of heater box out.
am not to sure which bit you broken inside ,any pics? and pictures of the metal clip?
Posted 22nd May 2011 at 16:27
ady347
i managed to get it off now cheers, i removed the matrix by cutting through the pipes on inside of car (part of the old matrix). then i couldnt remove the rubber pipes in engine bay where it connects to what was basically left of old matrix. i found a metal clip that you remove where rubber pipes join matrix, their is also a plastic lever i found you have to move to release rubber pipes. hope that makes sense.
Posted 22nd May 2011 at 19:55
ady347
ok, the only last thing i need help with is im going to flush out the cooling before i reconnect the matrix and undo the bypassing.
how much antifreeze in litres do i need? and also how do i refill and make sure i have no airleaks.
Posted 22nd May 2011 at 23:26
mike rallye
2 litres should be enough antifreeze and top the rest with water. you will need to bleed the system. there be one bleed on the top of the radiaotr,then one on the heater matrix pipe and should also be one on the side of the of the block,by the thermo stat. when you blead all of them run the car up to temp for the fans to cut in.
Posted 22nd May 2011 at 23:39
ady347
so i fill up the car with antifreeze and water first, then do i run the engine up to hot before i start bleeding? i presume i bleed one at a time, does it matter where i start? do i bleed it like my radiator lol, undo it a bit let out air as soon as water seeps out tighen it up again.
Posted 23rd May 2011 at 01:10
Start the bleeding with the radiator, then the thermostat and then the heater pipe....
One at a time, make sure you get coolant through with no air and then tighten up. However, whilst doing this make sure you have the heater turned up full heat to get the coolant around the whole system. Smile
Stan.
Posted 23rd May 2011 at 04:01
ady347
HI, cars back together now whoo hooo!! i have flushed the system and ready to refill but want to make sure i get this right! when i have filled it up with antifreeze and water do i replace cap? then do i run the engine up till its hot and put heaters on hot, then start bleeding?
i can see a plastic thing that turns half a turn on radiator is that a bleed screw? i can see the one by matrix hoses, but cant see one on thermostat.ideally i could do with a quick step y step if poss.
Posted 23rd May 2011 at 20:05
