Author Subject: Definitely the Steering rack?
musclebeach
The cars making a clunking noise whenever i turn the wheel, maybe 5 clunks to each direction...
Also with the engine off, and slightly turning the wheel it turns to a twanging noise.....
Does it sound as if i've got a leak and the moving parts are pretty much drying up?
f*ckING LOWERED CARS!
VW Golf GT TDI 115, 100k nooooooooooooooooooooo!
Posted 21st May 2011 at 02:09
gota6again
I'm getting this but weren't sure if it's a CV joint? I get a when I turn the steering wheel and when accelerating in 1st and 2nd mainly.........f*cking 10 year old French hatchbacks
Posted 21st May 2011 at 03:25
musclebeach
Yours does sound more like a CV joint or similar i'd say fella.
Mine ONLY does it while turning, which is making me suspect the dreaded steering rack!
Posted 21st May 2011 at 03:27
Not heard of a rack drying out but have had problems with clunky right turns due to broken top engine mount Unsure
Posted 21st May 2011 at 03:32
gota6again
Damn, oh well, more new shiney stuff for the car LOL
top mount bearings probably.
Posted 21st May 2011 at 13:24
Could be the universal joint in the steering column
Posted 21st May 2011 at 14:37
musclebeach
Hmm well it'll do it at 5mph or 30/40mph and the more i turn the wheel the more it clunks!!
Thanks Adam, also as a thought it's currently following bumps in the road (steering pulling) and it seems heavier than usual, also when straightening up after turning into a junction for example....the steering's in no rush to straighten back up and i usually have to pull it back myself.
Needs a bit of money spending on it now, sounds like it could be a couple of things then due to excessive stress! I haven't lost any PAS fluid so i suppose it can't be a leaky ram or anything
Can any of the above (top mount bearings/universal joint) be inspected visually?
Posted 22nd May 2011 at 01:01
