Author Subject: Vacuum pipe problem!!
m@tth
Hi, while rummaging around under the bonnet of the S16 and scratching my head i noticed the vacuum pipe coming out of the ecu and wondered where it went to so started tracing it back towards the engine only to find the end of it connected to nothing!!! It had a T piece on the end of it so i thought it might be the pipe that goes to the avac diaphrams??? Can anyone confirm or correct this for me please. Many thanks,Matt.
Posted 20th May 2011 at 23:11
dan_s16
No, that is the Map sensor (built into the ecu), it needs to be connected to one of the outlets on the inlet manifold on it's own.
Posted 20th May 2011 at 23:39
mr swampy s16
**BAD SELLER**
Yes mate its part of the inlet system.
It runs in to a white filter then on to the inlej.
I have some pictures of it some where ill load them later when im on the pc.
Posted 20th May 2011 at 23:42
m@tth
Oh!! So can i connect it anywhere on the inlet manifold and would this cause it to stall on idle but run ok whilst revving it with it disconnected???
Posted 21st May 2011 at 00:32
m@tth
Yes please that would be a great help. Think im going to need all the help i can get putting this vacuum system right!! Thanks again.
Posted 21st May 2011 at 23:30
