I'd been told last year I had headgasket failure, and left car off road for a year. another mechanic did a "block test" twice and no exhuast fumes were present.
We changed the rad fans and everything seemed ok until last saturday, the second day of having my six back.
Car had been running fine for 2 hours, then got stuck in traffic for a few minutes and temperature when balistic, i mean sky high.
I got it to the garage (who isn't a specialist) and we noticed a ton of rust in the coolant, and no coolant in the coolant!
We've completely bled the system, flushed it out and added some coolant. It seems that the fans only come on at 107 degrees (the passenger side) but the right one doesn't ever.
Have tried turning on air con to force slow speed but nothing happens.
I just took it on quick drive to work and it was fine this morning. Hoever on the way home i had some white smoke out the back.
I got home, left it for an hour, took the cap of and the pinky coolant still wanted to escape out like it was still under fairly high pressure.
I'm unsure what's happening.
Did it first overheat because it ran too hot, i got a pressure lock and then the temperature has flown up, blowing my gasket?
How can you check if the water pump is working or is dead?
I've had such a rough time with this car i am at my wits end....
Background info:
http://www.306gti6.com/forum/showthread.php?id=137015&page=1
Cheers all for any advice...
Troubled Moonstone owner.
garm
