I have a misfire but not from cold, after 2 mins its a misfire, 2-4000 revs its bad, 4-6000 its better, 6000 and above worse, I have changed plugs and coil packs, its got plenty of fuel, could anyone suggest what to check next please
Thanks Pat
| Author | Subject: rally car misfire |
flynn
Junior User Location: belper Registered: 04 Jun 2009 Posts: 53 Status: Offline |
Got a puncture on last rally on right front, what does the thick wiring loom under arch feed??I have a misfire but not from cold, after 2 mins its a misfire, 2-4000 revs its bad, 4-6000 its better, 6000 and above worse, I have changed plugs and coil packs, its got plenty of fuel, could anyone suggest what to check next please Thanks Pat |
rikky
Pikey
Location: cheshire Registered: 28 Feb 2004 Posts: 26,801 Status: Offline |
it goes right from the scuttle from the dash right to the front crossmember and then to the engine at 2x multiplugs, so it could be anything. you would be best off pulling the arch liner off and stripping the wire back from say the foglight area to the scuttle area (bout a metre's worth) and check for damage thereit is basically your full loom - so could be anything ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
Compression test...?________________________________________ Nothing to see here |
flynn
Turned out to be 2 problems, a broken wire on throttle position sensor, plus a tiny crack on the 3rd coil packPat |
