Author Subject: S/C starting
simonjames
Last month the rallye failed to start I found that the plugs were not sparking to the tip ( ngk irridium 7s fitted) I then read that 8s were better for track use so ordered some irridium 8s but on fitting them it turns over fires then stalls a few times before it will run is this down to colder plugs or due to boost pipe closing up on turn over
MY EBAY ITEMS
07943066306
Posted 17th May 2011 at 01:55
mabgti
NV motors
nope... i ran 8's with nitrous with no problems a few years back
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 17th May 2011 at 02:07
simonjames
Must be the pipe collapsing then
MY EBAY ITEMS
07943066306
Posted 17th May 2011 at 02:17
greenbelt
Any length of silicone will collapse on idle Yes
The only way to eliminate it is to get solid pipes made to measure.
Standard Black 6
Black HBSC6 Smoke
Posted 17th May 2011 at 02:49
simonjames
Yeah I know I only have the reducer 45 on the charger the rest is solid
Another thought is that its mapped with 2" pipe but I've now fitted 2.5"
MY EBAY ITEMS
07943066306
Posted 17th May 2011 at 03:08
spiky
mine will start and run with a collapsed pipe, so you can eliminaten that
infact i'm pretty sure i started mine without a boosy pipe connected
you have other issues
try looking at the crank sensor or the double relay
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 17th May 2011 at 12:57
simonjames
Crank sensor and multi relay both been swapped from my other 306 so i know they are fine, before fitting the boost pipe work it wouldnt start though i thought this was normal as when the pipe work was on all was fine untill i fitted the clamps and the pipe started closing up, it closes so far that i'd say it stops any air flow so i have no doubt that it is a factor but not sure if its the only problem
MY EBAY ITEMS
07943066306
Posted 17th May 2011 at 14:53
spiky
ah ok, when mine closed up (before fitting metal) it would still tick over but it didnt fully close, like yours
MY YouTube Videos'
Posted 17th May 2011 at 14:57
simonjames
im thinking about cutting a small piece of pipe say 20mm wide and slide that inside the bend so there's less chance of it closing all the way
MY EBAY ITEMS
07943066306
Posted 17th May 2011 at 15:08
spiky
thats exatcly what i have done and it seems fine,
track day next week so will see how it holds up, but has been fine for WOT on the road
MY YouTube Videos'
Posted 17th May 2011 at 15:11
simonjames
Great thats what i'll do then when its in the air having the decat fitted
MY EBAY ITEMS
07943066306
Posted 17th May 2011 at 15:14
birk
Take a boost pipe off the inlet and turn the car on, if it revs up on its own then you know its the pipe work thats the problem.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 17th May 2011 at 17:27
simonjames
I just put some std 6 ngk's (standard engine part) and it fired up fine so im thinking i might just fit irridium 7s and see what they are like
MY EBAY ITEMS
07943066306
Posted 17th May 2011 at 17:59
spiky
i'm using
NGK Spark Plug - Reference: BKR8EIX
i though 7's weere wrong?
MY YouTube Videos'
Posted 17th May 2011 at 18:01
rich_w
The problem is the plugs - 8's are too cold for a low-boost unless it's a pure track / race car and constantly thrashed.
The problem is they won't be getting hot enough for the self-cleaning process to work, they will be getting fouled up very quickly, and that's why it's not running.
Contact Details:
07732 822546
Posted 17th May 2011 at 18:02
spiky
ah glad you posted, was going to point him towards this threaad
http://www.306gti6.com/forum/showthread.php?id=128248&page=1
mine's a track car so happily sticking to your advice and using 8's
MY YouTube Videos'
Posted 17th May 2011 at 18:06
lotek
and thats How for nowwwwwww... LOL
simonjames
It will be a track car that will also be used on road, since fitting the 8s its only run for 10mins for 3-4 times, so i might just get some 7s for road use and refit the 8s when going out on track
Cheers Rich for clearing that up Smile
MY EBAY ITEMS
07943066306
Posted 17th May 2011 at 18:10
spiky
i've started mine quite a few times tickover and starting has been perfect
not seen a track yet,
pottle about or flat out it's been sweet,
MY YouTube Videos'
Posted 17th May 2011 at 18:16
simonjames
Not sure why mine would be different then, maybe the map being done on 2" pipe standard pulleys and flywheel and now it has 2.5" pipe solid pulley and lightened flywheel
MY EBAY ITEMS
07943066306
Posted 17th May 2011 at 18:23
spiky
was the 2" a custom map or is that what they are all mapped for
only asking as currently i only have a 2" and i'm going for a 2.5"
MY YouTube Videos'
Posted 17th May 2011 at 18:25
simonjames
it was custom as far as i know
MY EBAY ITEMS
07943066306
Posted 17th May 2011 at 18:34
