Author Subject: Torsion Bar, Spline Rotation
cornish_pug
On my 306 the drivers side Torsion bar is 15mm lower than the passenger side since i've had the car, 6 months now & it hasn't got any lower on this side in that time, people have said to me it's a knackered beam, but i've come to the conclusion thats it's just miss alignment of the drivers side torsion bar. So basicly i need to turn the bar back 1 spline (15mm approx). Which direction do you turn the drivers side to rise the ride height for this side.
Team Diesel
Posted 15th May 2011 at 23:13
you just set the height of the trailing arm and slide the torsion bar in wherever it goes, there isn't a specific mm per spline recorded.
there must be something wrong there to cause it to sit lower.
Posted 15th May 2011 at 23:39
cornish_pug
Ok, i've just read about the splines, according to Haynes the splines on the passenger side disengage just before the drivers side, thus allowing you to make adjustments on either end. Before sliding the bar back in place.
Team Diesel
Posted 16th May 2011 at 00:39
Rich E Forum Admin
I think you've got confused somewhere. You can't adjust the height on the drivers side without removing the torsion bar on the drivers side.
When you say the torsion bar is 15mm lower do you actually mean the ride height is 15mm lower?
Posted 16th May 2011 at 00:51
cornish_pug
Yes drivers side sits 15mm lower when the car is on the ground than the n/s. It always has done since i've owned the car
Team Diesel
Posted 16th May 2011 at 04:31
Bent stub axle ?
Posted 16th May 2011 at 04:35
as above, or the gound where you park is not flat LOL
Posted 16th May 2011 at 17:41
martinj
or mis-aligned end plates on the ARB maybe?
- Maxi rear axle hub spacers +53mm per side
- Maxi front steering rack extensions +40mm per side
Posted 16th May 2011 at 17:51
Do you keep a fat bloke in a back seat at all?
Posted 16th May 2011 at 17:52
bennn
When i adjusted mine on my first 6 there was about 7mm difference between sides. I think its normal and if you couple it with uneven ground i doubt 15mm is anything to worry about.
Even if it is lowering the other side to match isnt the right solution!
Cherry Red 306 HDI
Posted 16th May 2011 at 17:58
Rich E Forum Admin
As noted, many cars left the factory with a small difference in ride heights but 15mm is excessive and unlikely to be due to assembly tolerances.
I've just looked back at your older posts and given that you've posted in an older thread that you have arch rubbing on both sides I would say the trailing arm bearings have collapsed.
Posted 16th May 2011 at 18:07
cornish_pug
Those older posts where for my old 306, plus the last car had 17's where as this one is on cyclones.
Team Diesel
Posted 16th May 2011 at 23:35
wheels wont make a difference.
all the beams I've lowered have sat within a MM.
Posted 17th May 2011 at 00:49
Rich E Forum Admin
So you've had exactly the same problem with two different cars in the space of 2 months?
Clicky
Either way, with the limited information given my diagnosis remains collapsed beam bearings. What are the camber angles like? Heavy negative camber (the wheels angling inwards at the top) will confirm collapsed bearings.
Posted 17th May 2011 at 07:51
budgie
will anyone do my torshin bar its a 306 hdi will pay dont worry about thatjavascript:smiley('Big grin')
306 powwwwwwerrrrrrrrr
Posted 30th May 2011 at 23:16
mike rallye
have you sorted this now budgie?
Posted 17th Jul 2011 at 20:58
