Author Subject: Aux belt for no a/c or PAS
24seven
So having temporarily run without the power steering connected on my 309 VTS conversion I actually really like the feel without it. At the moment I'm running the full PAS and A/C belt & tensioner setup, but since the PAS needs the fluid and neither of them don't work, I thought I'd save the space and remove both pumps and the PAS reservoir and just have a belt to the alternator.
Long story short, is there an off-the-shelf solution to an auxillary belt setup with the PAS and A/C removed?
Posted 11th May 2011 at 20:37
Pretty sure you need to make up a custom adjuster etc to do this,as the belt will be running totally different route.
Think I've seen one on 205 forum where they made a bracket so the alt was adjustable to tension belt.
Then just measure how long it is round your pullies and got to motor factors and see what size suitesWink
Posted 14th May 2011 at 03:12
Rich E Forum Admin
I don't think it's a custom made adjuster. The standard 1.9 Mi16 arrangement used a bracket to allow the alternator position to tension the belt, and I believe it's a 205 GTi belt that's needed.
Posted 18th May 2011 at 17:08
24seven
Advice on the 205 forum was to use a cambelt tensioner and a 700mm belt. There's a thread in the bracket on that part of the engine that the tensioner can be bolted to so that it's only driving the alternator Works like a charm.
thanks anwyays folks. Smile
Posted 19th May 2011 at 02:53
