Happy to be back in a 306 again!
| Author | Subject: WONT IDLE |
simbob
Regular Location: cinderford Registered: 18 Feb 2010 Posts: 337 Status: Offline |
Hi guys hope fully one you can help, My rallye wont idle, I've changed the coil packs, and idle speed control valve, and changed the spark plugs for new genuine items. HELP HELP please cheers sim________________________________________ Happy to be back in a 306 again! |
mwl001
Regular Location: Bolton Registered: 24 Jul 2005 Posts: 422 Status: Offline |
Have you done an engine management system reset (i.e. disconnect battery, leave it for a bit, reconnect it and go for a drive?) |
simbob
Cheers I'll try it ________________________________________ Happy to be back in a 306 again! |
Check the wiring to the ICV too.Does it run ok otherwise? ________________________________________ Nothing to see here |
simbob
No it doesnt idle what so ever !!!!!!!!!!!!!!!!________________________________________ Happy to be back in a 306 again! |
simbob
just tryed the reset and taken her for a run no change :-( PLEASE HELP________________________________________ Happy to be back in a 306 again! |
bennn
Seasoned Pro Location: Shrewsbury Registered: 05 Sep 2008 Posts: 2,705 Status: Offline |
Tried disconnecting the ICV and seeing if it idles then?________________________________________ Cherry Red 306 HDIChampionship White Integra DC5 Type R |
lotek
Seasoned Pro Location: Berkshire Registered: 04 Dec 2007 Posts: 6,107 Status: Offline |
if you have replaced the ICV thenswitch the ingition on as far as it goes but not enough to start , wait, and repeat like 5 times This will help set the position of the piston. after that try and start car. ![]() |
simbob
Hi just tryed to do as lotek has suggested still no joy :-(________________________________________ Happy to be back in a 306 again! |
puglover
Banned!Location: Far out there Registered: 08 Jun 2006 Posts: 6,095 Status: Offline |
is it all over the place going up and down or just idle speed is high?? |
mattgti6phase2
Seasoned Pro Location: inside my 6 abusing the tarmac!! Registered: 16 Jul 2010 Posts: 2,371 Status: Offline |
is the TPS plugged in?________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
simbob
It not all over the place just won't idle :-( everything is plugged in as it should be . Just tryed starting it without the icv unplugged and is the same :-(________________________________________ Happy to be back in a 306 again! |
bonzo
Seasoned Pro Location: Telford Registered: 06 Nov 2007 Posts: 2,272 Status: Offline |
map sensor maybe?________________________________________ Black Rallye |
simbob
How do I check if it is or not ???? ________________________________________ Happy to be back in a 306 again! |
bonzo
I just replaced mine, guess you could try and give it a clean with some carb cleaner, but I don't know if that will be effective or not.________________________________________ Black Rallye |
mattgti6phase2
I bet it's something small and simple that you have just missed. Follow the process of what you did from start to finish and you may stumble across the problem. Did you secur the icv properly? Eg are the the 2 bolts tight enough? They're may be an air leak if it won't idle ![]() ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
simbob
Hi all car is fixed it was the map sensor. thanks for all your help ________________________________________ Happy to be back in a 306 again! |
bonzo
