Author Subject: aeroquip hoses
clen666
Does anyone know the best (read cheapest) place to buy aeroquip hoses and fittings from?
cheers
Team 'unintentional rat look'
Posted 6th May 2011 at 21:54
rallyeash
www.torques.co.uk Thumbs up
i got some bits from there before, top service and prices
309 3dr K20 Type R
Posted 6th May 2011 at 22:01
clen666
Cheers ash!
Posted 6th May 2011 at 22:28
chris with a pug
plus one for the above people, buy all my ones from there. Good service and parts look spot on
Posted 6th May 2011 at 22:31
clen666
They do seem to have everything required Thumbs up
Quick question, would it be possible to weld these onto the fuel rail for direct fitting?
Posted 6th May 2011 at 23:16
rallyeash
probably possible, although just buy the "hose finishers" then you can clamp the braided hose down to the standard fuel rail.
you will want -6 pipework and fittings which is 5/16 pipe.Smile
309 3dr K20 Type R
Posted 6th May 2011 at 23:23
clen666
For -6 for both? -8 works out as 11mm ID, would that be too large?
Posted 6th May 2011 at 23:29
spiky
yes you can weld straight on the fuel rail, i have done the exact same thing, see my build thread
but as ash says, -6 is all you need
www.torques.co.uk is run by my mate, mention my name PRE order and you get some kind of discount Smile
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 6th May 2011 at 23:30
spiky
MY YouTube Videos'
Posted 6th May 2011 at 23:36
clen666
Ok cheers spikey!
So I would only need -6 if using the weld-on fittings? I assume the -6 wouldn't stretch over the 10mm outlet on fuel rail, that's why I asked about -8?
Posted 6th May 2011 at 23:45
allanallen
I've used -8 in my car for the fuel feed and it's overkill to say the least. As suggested go for -6, use Teflon lined if your running it through the car.
The best way to do it is weld the fittings to the rail like spikys done.
I don't think you can use the Teflon lined hose on barbed fittings, you'll certainly not get -6 Teflon onto the 10mm fuel rail. Rubber -6 hose may well stretch over it but it'd be a bit of a Bodge really.
Facebook
Posted 7th May 2011 at 01:34
clen666
Thanks Allen you have confirmed what I was thinking, will try and weld on some fittings to fuel rail
Posted 7th May 2011 at 01:41
Use 312 stainless TIG rod if you don't want to risk a crack, the rail is mild steel and has a different shrinkage rate to stainless Wink
Also if you intend to use the fittings you linked to, grind some flats on the body so you can support the fitting with a spanner when you tighten up your fuel lines, otherwise you will twist the steel pipe and break it.
Posted 7th May 2011 at 19:39
clen666
Good thinking Thumbs up
In your opinion would the stainless steel or aluminium fitting be better? (I won't be doing the welding by the way)
The aluminium fitting is hex shaped so would save grinding it down.
Posted 7th May 2011 at 21:40
rallyeash
im no welding expert but think its not very easy to weld aluminium to mild steel
309 3dr K20 Type R
Posted 7th May 2011 at 23:09
clen666
I had heard welding aluminium can be tricky but tbh I know nothing about welding
Posted 7th May 2011 at 23:11
rallyeash
yeah aluminium is very different to welding steel. im sure daveyboy will be along shortly re welding the two different materials
309 3dr K20 Type R
Posted 8th May 2011 at 00:07
allanallen
You cannot weld aluminium to steel, you can however buy the correct weld on fittings in mild steel. Ask mr torques or search for -6 weld on fittings on ebazzle or google.
Facebook
Posted 8th May 2011 at 00:13
Actually you can Happy but in this case it would be entirely unsuitable to weld ally to steel, stainless to mild is fine, just buy the stainless weld on fitting you linked to and use the correct dissimmilar weld filler (312) i would'nt reccommend trying to MIG weld it as you will struggle like hell to stop it from leaking. I've done this job myself and its a piece of cake with a little TIG welder. (It helps if the the set is equiped with a foot pedal for increased control but not essential)
Posted 10th May 2011 at 19:21
