Author Subject: Front hubs
dan164
my o/s/f hub is knackered. driving around with the bottom ball joint isnt cool. just wondering if anyone knows the standard size for a 2000 abs hub, 16 or 18mm, just so i dont waste my money getting the wrong one off here, cheers
Posted 6th May 2011 at 17:28
pebbles167
I drive a 1997 Gti 6 and my ball joints are definitely 16 mm. I saw a late phase 3 hdi estate that was 18 mm which leads me to believe later models might be larger. Either way why dont you just pry the ball joint away and measure it? shouldnt take long at all. Also if you are replacing a hub then you will prob need to get a new abs sensor as well, they are a bas**rd to get off without breaking. Take a look at your local scrappy, bound to be an xsi or something hanging about with the correct hub.
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 6th May 2011 at 23:00
gtomi-6
only phase 3 are 18 then again unless you broguht the car from new they might have had 18's put on
ph3 gti-6 china blue- mint condition
ph2 gti-6 nile blue K.I.A dec 2010
Posted 6th May 2011 at 23:02
pebbles167
Ah right, well phase 3's are easy to find in pretty much any scrappy these days. took me ages to find an old xsi to grap my 16 mm hub off.
2008 BMW K1200R
Posted 7th May 2011 at 01:47
