displaying posts 1 to 2 of 2
Author Subject: temp sensors
24seven
Does anyone know if the green temp sensors with the square plugs have numbered pins? Also same for the MAP sensor. I've got round type but need the car running tonight and want to rewire the plugs from the square type on my loom to the round sensors I have.
That or if you could tell me which ECU pins go to which corresponding pin on the plug, that would be ideal.
Cheers,
Guy
Posted 4th May 2011 at 20:45
pugjim
I once found some info about something like this on a bosch website when i was doing a megasquirt project, it showed you the pinout for almost every bosch sensor available, i cant find the page now. Ill keep hunting though.
Posted 6th May 2011 at 02:28
