Author Subject: oil cooler
maddriver9
i currently run a 1.9 gti oil cooler on my 205 gti6 6 on bodies an just nearly finished rebuilding it with 87mm pistons an goin to be puttin big cams hopin for 210bhp will i manage with the oil cooler i,m running at the moment?
178bhp 205gti6
¼ mile in 14.2
Posted 3rd May 2011 at 02:12
Its a little small really, I'd be on the look out for a 16 row at least.
Posted 3rd May 2011 at 13:45
allye
I'm not so sure, its only in a 205 so not hauling about a 306 (I shouldn't say that on here should I!?) In the 205 it barely does anything anyway, I would see how you get on and go from there. I'm not using any oil cooler or water exchange on my standard 6'.
205 Van SC'd GTI6 - because why not
309 Goodwood V6 - sold
205 Rallye GTI6 - Bent
Posted 5th May 2011 at 04:34
matty_rallye
I would definitely recommed a front mounted mocal cooler. Unless you arent going to use it on track! A few people have ended up with bottom end damage on track without one, most likely down to oil temp being too high.
2.1 16v 306 Rallye.
Posted 6th May 2011 at 00:43
mikeygulley
I started out with no oil cooler on my '6 conversion allye and found the oil temp was quite high on longer drives at higher revs Ninja I now have a 16 row mocal cooler and it has made a great difference.
PSCUK Devon & Cornwall Group Leader
devon@pscuk.net or cornwall@pscuk.net
Next meet: TBA
Facebook: click here
Your chances are slim and none.......slim just left!
Posted 6th May 2011 at 17:04
