Author Subject: Rear brake bleeding and handbrake
rallye1999
Anyone know if the rear brakes need to have fluid in/ be bled for the handbrake to work?
Posted 2nd May 2011 at 23:14
mr swampy s16
**BAD SELLER**
Wouldnt of thought so as the handbrake is mecanical
Posted 3rd May 2011 at 01:01
Ding ding. The whole point of a handbrake is that it'll work in the case of a hydraulic failure.
Posted 3rd May 2011 at 18:15
rallye1999
Had a look at a spare caliper last night and it seems they need to have been bled so the piston comes into contact with the pads as there is only minimal movement on the handbrake mechanism, pumping the handbrake doesn't adjust them like on some makes, they were spot on before I removed them to fit some new boots on the back and regrease the sliders, I did however wind them all the way in to get the old fluid out
Posted 3rd May 2011 at 18:39
Bear in mind the handbrakes were pretty crap out of the factory, so don't expect too much Wink
Posted 3rd May 2011 at 18:44
I've read somewhere before that on our cars you should pump the pedal/bleed the rears before operating the handbrake.
Like mentioned, i guess its to do with the limited amount of movement in the handbrake mechanism so its useless without the pads almost in contact with the disc.
Posted 3rd May 2011 at 23:41
tvrfan007
If you've wound the piston all the way in then no, your handbrake it likely to do p*ss all when you've pulled it up 16 clicks.
If all you've done is let all the fluid out, and the pads/caliper haven't actually been disturbed, it'll be as good as before.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 4th May 2011 at 02:03
rallye1999
Oh I properly gave it a good draining and wound them right in ,should be right again after I've attached the new lines and gave them all some fluid
Posted 4th May 2011 at 02:10
tvrfan007
Yes it will be fine, just ensure you don't touch the handbrake until you've pumped the pistons right out and she'll be right. Not teaching you to suck eggs it's just easy to forget sometimes. Laugh
I'm Si btw Tee hee
Posted 4th May 2011 at 10:47
