Author Subject: Flashing STOP warning light
rich306.
This started last night, the stop warning light on the dash with every now and again just start flashing. Now I was under the impression that if there was an issue, it would stay on until that issue was resolved.
It started to rain last night while I was fitting a fuse closer to the battery for the power cable to my amp, so I'm wondering if it's possible that a sensor may have got a bit wet and is causing this?
Alternatively, could the earth for the amp cause something like this to occur? Because that is the only other thing that has been touched since before the light started flashing.
Just wondering if anyone could shed some light on the issue, any suggestions will be much appreciated Smile
P.S I have already checked all fluid/oil levels and all of them are fine. At the moment the light is just more annoying than concerning... LOL
Ex Bianca 6 Owner R.I.P
Mazda RX7 FD3s - Daily...
Posted 27th Apr 2011 at 19:38
Is it flashing steadily or randomly?
Posted 27th Apr 2011 at 20:03
rich306.
When its flashing it flashes fairly randomly, and it doesn't seem to have any sequence to when it will start flashing either.
Posted 27th Apr 2011 at 20:08
mark.evs
could be brake fluid or water or oil level. easy to check them first.
My GTi6 track project
White Rallye project
Posted 27th Apr 2011 at 20:14
mad_dave23
Do the fans kick in when the light comes on? If so then its a faulty connection on the brown temperature sensor, mine used to do thisjust take the plug off and clean up the connectors as best as possible.
Posted 28th Apr 2011 at 00:44
rich306.
yes they do! Thats great mate, i'll give it a look. Thanks a lot Smile
Posted 28th Apr 2011 at 01:10
cwspellowe
+1 for brown plug Yes
Bye bye Sundance Kid Sad
Posted 28th Apr 2011 at 03:58
ravemercer
+2 Brown plug
Just done mine last week New sensor Cleaned plug sorted the stop light and fans
Posted 29th Apr 2011 at 02:28
rich306.
Seems to have stopped of its own accord, I did disconnect the earth from my amp for a while to see if it had any effect.
I think what had happened was while I was under the bonnet and it rained the sensor may have got a bit wet but with the past couple of days of sun it has just dried out. I'm unsure but seems to be resolved for the time being anyways Smile
Cheers for the help guys. Smile
Posted 29th Apr 2011 at 19:56
