Author Subject: Pipercams
lurch86
Hello, I've been offered some piper fast road cams by someone breaking a 6. He has a receipt for when they were fitted, but the receipt only says tabout the inlet camshaft being changed? Would someone just change the inlet Cam? He says they both look the same. Is there anyway of checking the cams to see if they are piper cams? There must be part numbers on them?
Thanks
Wanted list... (P.m me if you have any)
Rollcage.
Strut Braces.
Lydden Hill 31/10/2015 Last Track day
1st time at Snetterton on the Bike! 22/08/2017
Posted 27th Apr 2011 at 01:37
yes.
Posted 27th Apr 2011 at 03:29
mr west
some people do just change inlet cam, i have some piper cams ready to fit i'll ook on them see if there is a part numder for yyou to check against
white rallye
cherry dead rallye
s16
Posted 27th Apr 2011 at 03:48
lurch86
Brilliant, thanks. Hopefully there both, as there a bargain if they are.
Rollcage.
Strut Braces.
Posted 27th Apr 2011 at 03:56
mr west
on the end of each cam it says..lj8m or lj8n not sure but also mine are 270 cams so that is on there too., hope that helps
white rallye
cherry dead rallye
s16
lurch86
Thanks for your help. Turns out there was only one so I didnt bother with them.
Rollcage.
Strut Braces.
Posted 29th Apr 2011 at 03:55
You can decent gains with just the inlet. You can play with the standard exhaust cam to suit to a point. Main issue is how much lift the cam gives you as there isn't much room.
Posted 29th Apr 2011 at 13:04
lurch86
Oh right, didn't know if just the inlet would be worth it. They are the smallest lift that they do. 0.043, 1.09mm. I'll find out how much the bloke wants for just the pipercam and decide from there, cheers
Rollcage.
Strut Braces.
Posted 29th Apr 2011 at 15:47
as mentioned, mapped properly and with the right inlet and exhaust, you could be well to 190 bhp I would imagine, retaining the standard exhaust cam will keep the torque up too afaik so should make a nice drivable road car.
I know a few 2.2 XU's on throttle bodies and decent exhasuts that have made 220-240 bhp with pretty much stock heads and an inlet cam only, impressive torque too.
Edit, which cam is it? may sill be quite mild but 1.09 IIRC is ok in a stock engine.
Posted 29th Apr 2011 at 15:51
lurch86
http://www.pipercams.co.uk/pipercams/www/product.php?pid=GTI6BP270H
Fast Road cams
Rollcage.
Strut Braces.
Posted 29th Apr 2011 at 17:01
lurch86
The bloke said I can have the cam for £30, so I cant go wrong really
Rollcage.
Strut Braces.
Posted 29th Apr 2011 at 16:12
mr west
don't the 285's need the pistons modding to allow the extra lift.
white rallye
cherry dead rallye
s16
Posted 29th Apr 2011 at 16:31
lurch86
Sorry, wrong link. Now edited
Rollcage.
Strut Braces.
mr west
sounds a bargin, just need to followers etc
white rallye
cherry dead rallye
s16
Posted 29th Apr 2011 at 17:33
lurch86
Do I need followers aswell? Would the standard ones not be the same?
Rollcage.
Strut Braces.
Posted 30th Apr 2011 at 02:58
mr west
you can use them but they will be worn to suit the old cam, is best to use new ones and bed them in.standard springs are fine though
white rallye
cherry dead rallye
s16
Posted 30th Apr 2011 at 15:19
lurch86
Oh right, yea thats fine. Thought you ment I'd need special ones.
Rollcage.
Strut Braces.
Posted 30th Apr 2011 at 18:05
rallyeash
i wouldnt worry about changing followers to be honest
309 3dr K20 Type R
Posted 30th Apr 2011 at 18:20
lurch86
I think there quite expensive (going by a set on ebay), so if I dont need to I'd rather not.
Rollcage.
Strut Braces.
Posted 1st May 2011 at 03:08
