Author Subject: XS to VTS conversion
jardo
Hi guys, I appreciate this isn't the best place to ask but you guys have a lot more knowledge than other 306/peugeot forums!
I'm looking to start a bit of a track project using my 306. Currently I'm running an 8 valve 1.6 TU but I'm looking to do a VTS/106GTI 16V conversion.
So, as far as I am aware the engine and gearbox mounts are the same and in terms of mounting the engine there are no issues. My car is a single pin ECU, so if I got a single pin early VTS engine I shouldn't run into any issues with running the engine through standard plugs and fittings?
I plan on removing the PAS, however I would like to keep ABS. However that will all remain in tact?
Basically I'm just after a bit of advice so I can keep mistakes to a minimum.
I know I will be told to "just buy a six" but I've got a mint shell which is perfect for building on. I already have a solid mounted rear beam, 6 discs and Koni suspension fitted, along with buckets, harnesses and all the bells and whistles. It's just missing the legs!
Any help would be great, I'm off to the Nurburgring on May 6th and I'll be doing the conversion when I get back and will hopefully have it up and running by the end of May.
Cheers Smile
Posted 15th Apr 2011 at 19:03
just buy a 6,..... Laugh
why are you dropping a vts/106 gti in?
for and extra 8v's
i'm all be for making a track slag but if I was to got to all that effort I'd drop a 6 lump in it at least,..
I'm sure someone on here is selling everything you'd need for £600
Posted 15th Apr 2011 at 19:11
as above, a 6 is so cheap these days its not worth it unless you have a multipoint caged shell already kitted out with proper trick suspension.
with the number opf already fadt road spec "track cars" out there, no point converting an XS
Posted 15th Apr 2011 at 19:16
jardo
I will be doing the VTS conversion as apposed to a GTI6 conversion, I've got my mind set on it.
One of the reasons for my stubborn-ness on the VTS engine is I already have a flowed and rebuilt head with cams and TB's from a friends AX project that never got finished. A single pin engine, box and engine loom with 30K is also up for grabs from the same project for not much money at all. It's more the convenience of a friend having all the parts sat waiting that pulls me to it.
I hadn't even looked into a 6 conversion, whats involved? Bearing in mind it is a track only build. I am not doing this to dodge insurance!
Posted 15th Apr 2011 at 19:32
honestly,...
buy those bits cheap as chips,
sell them on for as much as poss,
buy a cheap but well maintained 6 strip it out,
sell those bits using the funds to buy uprated track mods,
I would sit there p*ssing about trying to build one from scratch near enough,..
just my opinion mind you do what you want but to me that's a hell of a lot of work!
Posted 15th Apr 2011 at 19:40
jardo
From what I understand it will be a load easier to swap to a VTS engine over a 6 upgrade, and with my cam head and TB's will put out the same sort of power as a stock 6. I am not interested in changing cars, I've got a mint black shell with not a single dent, blemish or spot of rust. It's going to be an engine swap. The other one for me is I fancy entering local hill climbing and sprinting events in 2012 and having a 1.6 will put me in a lower cat ' for my local meets.
Can somebody just talk me through what is needed for a GTI6 upgrade? I have tried to search but found nothing so far.
Posted 15th Apr 2011 at 20:04
Unsure
you wont be in the 1.6 class as a gti6/vts is a 2.0, basically the conversion for both is identical, you need engine box wiring loom subbrake gear linkages driveshafts hubs cooling system exhaust rear beam
i.e the whole car bar the shell LOL
for a competition car, I would definitely not be choosing a mint shell, as it wont be mint for long...
Posted 15th Apr 2011 at 20:35
Welsh know's his stuff,...
just stop being stubbon take a step back and really think about what it is you trying to undertake,...
before jumping in feet first if your entering into hill climb contests then find out how the spec cless's work
everything you have is worth more in bits than all that hard work crammed into a mint shell that'll only probably get wrecked anyway,.
you can use the value of what you have and invest it in something faster which is the goal right?
not to plow your heart and soul into something that's not much better than it origilally was,.. to get troused by everything in your class
and then bin it,...
I'd love to do a track car but I wouldn't build one from scratch,...
I have a mum and a girlfrind I get rid of those and i'm good to go! lol
trade ya?
only track car i'm aloud is this,...
Sell you one when i'm done Shifty
Posted 15th Apr 2011 at 21:04
jardo
Unsure
Noooo, I'm talking Saxo VTS/106GTI engine! LOL
I don't *want* to do a GTI6 upgrade, but obviously the more powerful engine would be a more beneficial swap so I was just curios.
I want to stick 1.6 or under due to the categories for local sprinting and hill climbing, the TU J engine will offer me the easiest power upgrade. It was the reason I bought an XSin the first place. My current shell is mint, stripped and already fitted with buckets, harnesses and already has the suspension and brakes required to get me started.
I just want to know how compatible the VTS engine is going to be and wether anybody on here had done a Saxo VTR to VTS swap as my engine is essentially a VTR engine.
Posted 15th Apr 2011 at 21:07
oh, should have said!!! no point in a 306, they're too heavy, stick to the Saxo/106, significantly lighter.
its hardly any extra weight for the 2.0 engine which has LOTS more torque and a proper gearbox attached to it (the BE3)
even in a 106/saxo on a standard TU5J4 the MA shit themselves with hard use, add a heavier 306 chassis they'll die even sooner.
Posted 15th Apr 2011 at 21:15
rallyeash
another thing, if you have got tb's and cams in the J4 engine (1.6 16v ma) you will need proper managment and a loom to suit. this will be over 1k if you buy a dta, loom and mapping session.
gearbox's as above are shit on the TU engines, Be conversions are possible but hardly worth doing in a tu engine'd 306.
309 3dr K20 Type R
Posted 15th Apr 2011 at 21:23
jardo
Weight wise I'm pretty sure my car is not far off a standard VTS.
Gearbox issues are something I have accounted for, and due to the limited mileage I wasn't too worried but you guys are making me have second thoughts. Having only had dealings with two 205 GTI's and my current 306 I've never come across the famed TU gearbox issues but I've heard all the rumors. Whats so crap about them?
In terms of GTI6 conversions into my current shell, where would be the first place to look?
Posted 15th Apr 2011 at 22:35
dragoon
try comparing a stripped 306 versus a stripped 106, you'll be surprised Wink
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 15th Apr 2011 at 23:37
most 306's struggle to get under 1000 kilos without mega money being spent, however I know of a road legal TU5 engined 106 hillclimb car that is easily under 800 kilos...
he has broken several gearboxes with only 200 bhp mind LOL
Posted 16th Apr 2011 at 00:02
jardo
dragoon wrote:
Yeah, you do a search and you get unhelpful f*cks telling other people to do a search or if you search on the pug306.net forum you get unhelpful f*cks telling you to put a diesel in it! LOL
Or as this thread shows, you get people telling you not to bother in the first place and just "buy a 6"
http://www.306gti6.com/forum/showthread.php?id=107899&page=1
I sound a bit ranty there, it's not because I'm miserable or thick and don't know how to search. It's just that I have searched and have not found a proper "this is what you need to do".
Posted 16th Apr 2011 at 00:47
because most saw sense and didn't bother LOL
Posted 16th Apr 2011 at 00:51
jardo
I'm going to bother though LOL
People told me not to bother tuning my 8V, but I saw good returns on it and it wasn't all that bad. I just find it really unhelpful being told something I didn't ask for. I asked for any known compatibility issues when going from an 8V to a VTS engine in a 306.
If somebody could give me a definitive "this is whats needed for a GTI6 conversion" I would contemplate that instead. But as far as I can see a VTS swap would be a day job using 90% of the standard bits that I could do myself but nobody seems to know about putting one in a 306.
Posted 16th Apr 2011 at 00:59
indeed, now have you guessed why yet? LOL
Posted 16th Apr 2011 at 01:01
jardo
We'll see what I can do! If its a massive PITA I won't bother, I'll look to using another car for track day fun and selling on my 306. But I don't want to sell it Sad
Posted 16th Apr 2011 at 01:06
never recall anyone doing it, but the engine itself should drop straight in as the bottom end is identical, unsure if the top arm would need any modifying, then just the wiring to sort and an exhaust manifold to fabricate as they are different to the 106 due to having a subframe in the way (no subframe on 106/saxo)
Posted 16th Apr 2011 at 01:16
jardo
We'll see what happens Smile
I'm going to have a dig around a friends VTS at the weekend and take a few photos and see what I make of it. Thanks!
Posted 16th Apr 2011 at 01:38
swiftyboi006
I got a 6 for sale 96k near full history but it was a rite off due to the back end crumpled engine is fine you can have it for £500 theres everything uneed. Only thing wrong is a bent chassis
Black p3 Love
Posted 16th Apr 2011 at 18:28
