Author Subject: Oil in intake/throttle, cause?
jägertom
Evening all, nice to be back online Happy
Was left on the side of the M1 last Friday with the diagnostics throwing up a TPS error, and so was towed home, (only now do I realise I could've just unplugged it and carried on driving... Dry ).
So have dismantled my throttle body and retrieved the TPS, to find oil loitering inside the sensor (literally the casing's full). Also there appears to be a bit jus' chillin inside the manifold. I'm guessing its a bloody good bet that the oil bath it's received had a hand in killing the sensor.
My question to you is... Where could the oil have come from, and has anyone had this problem/solution before?
Valve stem seals?
Huge amounts of blowby? ( =piston rings on their way out?) Unsure
Any advice or experience much appreciated, as always...
Feelin so fly like a Gti6 Ninja
Team >160,000mi Sad
Posted 15th Apr 2011 at 00:11
some engines breather lots and otherwise drive fine, others dont.
Posted 15th Apr 2011 at 00:43
atterz
Engine oil breathers, these engines arent too bad but if its getting on a bit some will get past the rings. Its oil vapour from excessive pressure in the crankcase.
The Dtub use to puke oil all over the intake, all of the time! Consider fitting an oil catch tank, and clean all of the sensors with some Electrical contact cleaner.
owain wrote:
Posted 15th Apr 2011 at 00:45
jägertom
Thanks, yeah you could say shes getting on a bit, 158000mi...
Am I right in thinking the car should run if I unplug the TPsensor?
'Cos it doesnt... Blink
Team >160,000mi Sad
Posted 15th Apr 2011 at 00:53
atterz
Clean it up mate with electrical contact cleaner, or even brake cleaner if you are struggling!
Posted 15th Apr 2011 at 01:26
24seven
It won't run fine without the TPS, but it should run as long as yo haven't unplugged the MAP sensor as well. oil in the intake is pretty normal on these to be honest. I doubt that's the cause of your TPS failing, chances are it's just worn out or failed by itself.
Posted 17th Apr 2011 at 04:56
