Author Subject: Ecu issue , well, I think
spiky
Got the 205 back together running low boost sc, with a normal gti6 ecu the fuel pump primes and stops, but with the low boost ecu it's continuous?
Why would that happen?
Car runs and ticks over ok with both ecu's
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 19th Mar 2011 at 00:46
simonjames
does it not cut out when rail is prsured?
MY EBAY ITEMS
07943066306
Posted 19th Mar 2011 at 00:58
Rich E Forum Admin
Is it actually continuous or just on for a long time (30-ish) seconds, and have you repeated the test?
The ECU does prime the pump for longer if it's been unplugged for more than a few minutes, so that's a possibility if the standard ECU was pulled directly out of a car to test with.
Posted 19th Mar 2011 at 00:59
spiky
Both ecu's have be sat in garage for months, put normal on just incase I blew it up, it primed for 5-10 seconds then stopped, started car, ticked over
Then shut down, put lb ecu on and primed continuous
MY YouTube Videos'
Posted 19th Mar 2011 at 01:28
spiky
Just left ignition on again, and you spot on, nice one Smile
Lb ecu just needed longer , 10 seconds
MY YouTube Videos'
Posted 19th Mar 2011 at 17:38
